Starts with starting fluid..wont stay running
Old 10-30-12, 09:44 AM
kmoore737
kmoore737's Avatar
Default Starts with starting fluid..wont stay running
92 sc 400, starts when I spray starting fluid in the throttle body...won't stay running. Sounds like it is a fuel issue any idea how to do a quick check that I am getting fuel? Also no owners manual...is there a fuel panel inside the car if so Where is it?
Old 10-30-12, 09:46 AM
kmoore737
kmoore737's Avatar
I mean where is the FUSE panel...sorry
Old 10-30-12, 09:49 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Fuse panel is under the hood by battery and the other is in the driver side kick panel. i would check to see if the fuel pump is actually working. Remove the back seat and see if you hear it. if not might the fuel ecu acting up, known problem ... thats in the driver rear panel under the glass... good luck.
Old 10-30-12, 10:45 AM
kmoore737
kmoore737's Avatar
found the fuse panel...thanks...yep fuel pump is not working..is there a fuel pump fuse? if so which one and is there anyway to bypass the fuel ecu? fuel gauge does not work either...makes me lean toward that ecu...any ideas
Old 10-30-12, 11:12 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Sounds like the fuel pump.
coug66
11-17-22 09:28 AM
Phillip74R
01-14-17 05:50 AM
equix8
01-03-15 09:04 AM
lanthern22
GS - 1st Gen (1993-1997)
10-01-10 04:57 PM
Quick Reply: Starts with starting fluid..wont stay running
