O/D Flashing DTC89: Need help removing code
Old 09-25-12, 10:06 AM
93MSB
93MSB's Avatar
Default O/D Flashing DTC89: Need help removing code
First off, this issue is caused because the car for all intents and purposes is a 2JZGTE swapped 95 sc300 without any of the factory traction control components.
Relevent mod list:
1JZ Engine
JDM 2JZGTE harness merged with USDM sc300 harness
JDM Supra Auto ECU OBD1
Aristo Transmission
Symptoms:
The car runs and drives perfectly fine. The issue is the O/D flashes while the car is started/running/driving.
From what i can tell the engine ECU is looking for a signal from the TRAC ECU. Im just not smart enough with electronics to figure out what kind, or if its possible to fool the ecu. Ive done a lot of searching and even a researching of my own, but havent found anything that works
here are some diagrams and info i found from the TSRM
TRANS DTC89:
ECU terminal values
TRAC DTC 53
Old 10-22-12, 10:00 PM
93MSB
93MSB's Avatar
bump, ive tried a few things but no luck. I'm beginning to think I might have to have the trac ecu to get rid of it
Old 10-23-12, 10:48 AM
durps
durps's Avatar
Pm O.L.T he knows about this stuff.
UltraOptms
02-02-14 07:22 PM
Mr209sc300
SC- 1st Gen (1992-2000)
01-14-11 06:17 PM
CHASER4LIF
SC400 / 300 Classifieds
08-15-10 02:35 PM
Shadowen
12-29-09 08:06 PM
Quick Reply: O/D Flashing DTC89: Need help removing code
