I am in the process of redoing my head and I am going to go distributorless. Since I will no longer be using the distributor does this mean that I can use 2JZGTE cams?
as stated above its a 2JZGE non vvti motor
Correct, you can run any GTE cams in your set up if you delete your distributor...
