Battery Keeps Dying
Old 12-20-11, 11:52 AM
ScWift92
ScWift92's Avatar
Exclamation Battery Keeps Dying
This Is My Second Sc300 And Both Have Suffered From This Problem Why Does The Battery Die After Not Using The Car For 2-4 Days ????????????? I've Searched And No Answers Just Suggestions Any Help Guys ?
Old 12-20-11, 12:58 PM
scENFORCER
scENFORCER's Avatar
Not sure about everyones SC, but mine (and my audio guys old SC) both had larger than normal drain while not running. He said it was probably normal for all SC's.
Would be curious what everyone else's SC drains while not running..
Old 12-20-11, 01:19 PM
ScWift92
ScWift92's Avatar
i'm thinking that since i have a valve cover and distributor leak oil got onto my alternator and makes it harder to recharge so maybe....any one test theory's?
Old 12-20-11, 01:48 PM
INTIMAZY
INTIMAZY's Avatar
Funny enough, my 1JZ swap made the drain farrrr slower... Maybe a bad ground somewhere?
I relocated the battery to the trunk because I couldn't fit 3" intercooler pipes so I ended up putting the largest, heaviest battery Sears sells in the trunk. No more dead battery problems
Old 12-20-11, 01:51 PM
ScWift92
ScWift92's Avatar
hmmm i noticed everybody with a swap doesn't have this problem i think its based on my theory.
Old 12-20-11, 02:57 PM
MMCtuner
MMCtuner's Avatar
I disconnect the battery everytime I leave her resting some days. It seems is a common problem.
Old 12-20-11, 06:38 PM
Arkansas
Arkansas's Avatar
Ive got a power drain in my 400 somewhere. Once I get it running properly im gonna bring it to a shop and have then check all the grounds and possibly have a grounding kit made for it
Old 12-21-11, 07:25 AM
ScWift92
ScWift92's Avatar
how would i install a cutoff?
Old 12-21-11, 07:57 AM
maceugood
maceugood's Avatar
same thing happening to my 400, its got a good battery but if it sits 3 or 4 days it is dead. I think the cold weather has a lot to do with it.
Old 12-21-11, 08:10 AM
Batiatus
Batiatus's Avatar
My car came with a weak battery so I replaced it. Just 2 weeks ago I had to replace it again cause it wouldn't start after the car sat over the weekend. I only had that battery a little over 2 years. Luckily it was still under warranty.
I checked for a power drain and couldn't find any. I've even got a higher amp alternator and upgraded the grounding wires. I'm not sure why but it does seem to be a fairly common thing with our cars for the battery to give out early.
Old 12-21-11, 08:17 AM
ScWift92
ScWift92's Avatar
could it be the alternator?
Old 12-21-11, 08:23 AM
wirelesstj
wirelesstj's Avatar
something is pulling charge when the car isnt running. maybe ur footwell light is staying on? i also have a 1j swap and dont have that problem...
Old 12-21-11, 08:38 AM
Batiatus
Batiatus's Avatar
It could be your alternator not charging good enough. That is a common problem for oil to leak from the distributor onto the alternator and ruin it. If there is oil leaking on it I would check that first.
Old 12-21-11, 08:55 AM
levie
levie's Avatar
also have this problem with my soarer. very frustrating. i cant help but to think that some lights are always on. ill investigate next time its been running for a bit.
Old 12-21-11, 12:45 PM
ihiryu
ihiryu's Avatar
Edited for bad information on my part, read GS4_fiend's post for the right way of doing it
Quick Reply: Battery Keeps Dying
