2jz bellhousing bolt sizes. help please
Old Nov 5, 2011 | 07:28 AM
milkyninja's Avatar
milkyninja
Default 2jz bellhousing bolt sizes. help please
i can't find the sizes of the 2jz bellhousing bolts with a w58 transmission. the only thing i found is the sizes of a 2jz block and 1jz bellhousing which are There are four 10mm x 1.25 x40mm, five 12mm x 1.25 x 50mm, and two 10mm x 1.25 x 70mm (starter). i read somewhere els that the bellhousings are the same though. just the gearbox to the bellhousing is different. someone chime in and get me on my way please? thanks!!
Old Nov 5, 2011 | 08:54 PM
milkyninja's Avatar
milkyninja
anybodyzz? :/
Old Nov 5, 2011 | 10:24 PM
TLDriver's Avatar
TLDriver
I used my #jz/w58 bolts on my #jz/r154 bell housing... should be the same ones on an auto.
Old Nov 6, 2011 | 05:36 AM
milkyninja's Avatar
milkyninja
im not doing auto to manual swap. im doing 2jz swap in a 240sx. i got the engine and transmission seperately. so there were never any bolts. ill try these ones i just got from advance. thanks for your input.
Old Nov 6, 2011 | 06:44 AM
TLDriver's Avatar
TLDriver
good luck on the swap and I want to say it will work.
IneednSC
Feb 17, 2014 04:38 PM
Orionsc300
Jan 15, 2011 02:52 PM
Confusion
Dec 25, 2010 08:30 PM
lowkeySC
Dec 4, 2009 06:09 PM
SCjzz
Aug 21, 2008 03:19 PM
