what reservoir do I use for a GTE swap?
I have a reservoir and pump hose from the stock 2jzge. would it fit ? or would i have to get a reservoir and hose from a supra?
also for those with GTE swapped sc300, currently my car doesnt not have AC, do i have to get custom hardlines to run it with gte swap or can i use the stock hardlines from the sc300?
any help would be appreciated,
thanks brian
thanks brian
gte & na-t
the ge p/s pump will work but you will need the fittings, o ring and the little 10mm bolt to convert it to a tt pump i did it on my car check out my thread i have the part number on there too.
https://www.clublexus.com/forums/sc-...-daily-13.html
power steering reservoir you can either buy one for a tt it's about $168 or you can make the SC400 reservoir fit.
gl
gl
USDM GTE res, and as far as lines, depending on where you mount the res, you can just use normal high temp hose to mate the res to the pump. It's very easy. On my customer's swap I just finished, I also ran an aftermarket cooler, so my lines are a little different than yours might be. I'll try and get pics up in the build thread.
-Cam
-Cam
PMP 300
Performance
26
01-30-12 09:08 AM
