Climate Control lighting and cigarette lighter
#31
had a similar problem, turns out there's 3 fuses involved in running the climate control ....Cig lighter....dome light...and I believe the last one is marked heater or something like that, Hope this helps
#32
hey guy i some what figured out my problem, i replaced the temp ecu on the passenger side under dash, its a blue box., everything works and all buttons are responsive now., but i have no air coming out, doesnt matter what speed or mode i set it, no air, seems like the blower motor is dead, any idea ??? thanks
Also, my cigarette light has never worked, I took my car apart and didn't even find the plug for it. Anyone have a picture of it, and what plug it comes out of??
#33
I've got a similar problem, replaced LCD screen, but upon power up, there are no more backlights on the climate unit. The screen and unit function fine, but there is no backlighting whatsoever (screen or buttons). Anyone have any ideas?
Also, all the fuses are good.
#34
having this same issue now. Cig lighter and LCD screen work on the climate control. AC and all the controls for it work just fine. just dont have any back lights for the buttons. The radio hasnt worked since i bought the car so I pulled that fuse under the hood. Did you fix your issue? Is my climate control bad?
#35
Having same problem after install new head unit on my 2006 es330 climate control and cigarette plug work just fine just the backlight not turning on on the climate control, on the back of the climate control there are three connector when I pull the left one out the backlight on the LCD turn on so I know the backlight is not blown, it just won't turn on any idea
mischief7
SC- 1st Gen (1992-2000)
09-02-08 03:32 PM
