chirping sound coming from car
When driving (and sitting still)I hear a chirping squeky sound coming from the car. What's weird is when I press in the clutch it stops for a little then starrts again. I have a 92 5spd sc300
if it's coming from underneath the car it's definitely the throwout bearing.
if its coming from the engine bay it could be either the alternator, water pump or the belt tensioner pully going bad
Sounds like the throwout bearing to me too.
Originally Posted by OneJay
(Post 6516604)
If it goes away when you push in the clutch, most likely your throwout bearing. |
+1 on the throwout bearing, had the same problem when i replaced my clutch myself i used the wrong kind of grease to lube it up, be sure to use white lithium grease and not red wheel bearing grease. so either fix it or turn your radio up
| All times are GMT -7. The time now is 12:16 PM. |
