Fresh 1jz Swap just finished No Key Start
i just finished my swap tonight, i have no turn key start, the car was an original automatic, i got my swap with a full manual r154 and harness. so i have no neutral saftey switch to bypass because its not there anymore. i did many thread searches. and nothing comes up solid. im guessing i might just have to run a wire to the starter relay to the ignition switch. but if there is a cleaner way to do it. someone inform me please.
i like to do things myself. but if i can read up and answer i'd appreciate it. someone should really sticky a thread on how to do this if u purchase a full manual swap with harness into an AUTOmatic sc300. most of the help i've been reading is if u do a swap and keep the auto ecu, but put a manual behind it. i dont wanna do it that way and didnt. so any help would be appreciated. Jared aka DoomLight!:sad: |
what car is your r154 engine/harness out of?
Originally Posted by cartmill
(Post 6221188)
all the plugs fit. |
Originally Posted by eyeSOARER6
(Post 6221215)
maybe i missed something that pertains to the automatic body harness that i can manipulate. |
post edited for misinformation...
Sure, here's how you do it. Run a wire from EB1-3 to NSW(76B) on the ECU
Taken from: http://forum.clubna-t.com/showthread.php?t=7327 Turns out I was wrong about the NSS being by the ignition. It's actually part of the harness. Imagine that... Also, I searched and found this: https://www.clublexus.com/forums/per...with-pics.html |
i think i will make a new thread showing my progress.
