Distributor Delete Pics w/ 7m-gte CPS / vvti Coilpacks
#260
#262
ali
i am finally going to have to do this conversion , my hks dli is finally about to crap out after 10 yrs of service and you cant find these anymore so might as well do this vvti cop upgrade .. i have done many things on these/my cars from swaps to builds but never done this particular upgrade.. I understand the entire process but have 1 question , the resister mod on the cluster , is this the same for a 97 cluster .. and 2nd question , on 98 -2000 modelas having same cluster as 97 , how do they get tach signal
#267
Ok need help from the guru's , mainly Ali and Gerrb
Yesterday finally attempted to do conversion. I have bought a premade cop harness from cx racing with clips and all as it was well made for 70.00. before wiring in I checked continuity for each coilpack connector and all verified . I had a spare ge harness and butchered it to get matching wires to splice in from new wires coming from dh61 igniter harness so I had original pins at the ends (I de pinned wires from spare harness ECU plug) and after making this harness checked continuity as well and all checked fine from pin to wire end. De pinned original igniter pins one by one and pinned correctly to new dh61 igniter and verified like 5 times.
Heres my main problem. It's pin location on my ECU plug. My car is a 97 and ECU pin out doesn't quite match up. I already have pins in position 52 and 57 and 53 and 54 55and 56 which I don't understand. I plugged t3 and t2 into slots which I thought were 55 and 56 and adjusted all settings. (one setting I found odd in my aem cal was in the options for setting cam /crank to falling edge , mine was set to cam falling edge and crank to rising edge)..
Car tries to start but will not idle so I can't sync timing unless she at least stays running ... it sounds like it was running on one cyl.. I have a feeling its due to t2 and t3 not in correct positions
What's your take
What's your take
#268
Maybe was tired and frustrated and hot and sweaty yesterday but this morning while sitting on throne lol I had my spare ecu plug with it pinned in front of me and was looking at the pin out. .. when looking at aem pin out diagram should I be looking at the plug from side where pins go in or from side showing pins themselves. For at least on this harness ecu plug if I turn it looking at side where you insert pins then pin 57 and 58 are there and 56 thru 51 empty ...i haven't looked at my own ecu plug yet to verify but will do later but if my memory serves me correctly I think I saw 57 and 58 occupied but 56 55and 54 not but 52 was ( may on 97 harness they tie 52 and 57 together somehow.
Man I hope I was being a dumbass as electrical stuff not really my thing
So which way should I be looking at ecu connector when referencing aem 1101 /6101 pin out diagram
#269
If you're looking at the female side of the plug (the one with all the holes), then pin 1 will be top left.
lexforlife (09-04-17)
#270
Super Moderator
Ed - whenever you are dealing with our Lexus SC wiring , regardless of which one in our cars ... hold on any connector facing you meaning pins in front of you with the lock tab on top and wires behind . Number one (#1) pin will be the top left most ... then go to the right most counting ... then go to the next row continue counting left to right till you get to the pin number you are after . That will be the easiest way to find which pin you are looking for ... then just grab the wire behind for that particular pin .
You get the hang of counting those pins with the way I just mentioned , then it will eventually be easy as time pass.
ECU or component pinning will be the opposite .. Top Right is #1... then count going to left .. then next row .. right to left, till you get to the pin of the ECU or component that you are after .
