1jz/2jz compatibility questions?
Are the 1jz and the 2jz rear main seal, cam seal, and crank seal the same part number? just wondering if anyone knew. Id like to throw in a rear main seal with the trans sitting in my trunk and if its readily available. hopefully someone knows?
98 percent positive. same bottom end, just shorter stroke. i should done that on my last clutch swap, now im gonna go 1.5jz
| All times are GMT -7. The time now is 12:54 AM. |
