!NEED HELP! misfiring??
I recently when under a tune up after a recent bad battery explosion went off on me but now i've ran into another problem. I recently changed my battery of course, rebuilt the alternator, replaced distributor cap rotor and o-ring, checked sparks and wires all of them working in god condition. Car starts up perfectly fine but after it warms up it start to misfire i guess a more of boop boop sound every now and then till it dies off. Also when i rev it up it will also have the same misfiring i suppose. So far im going to check fuel pump,filter, injectors. Also its a NA 2j auto. Any body got some suggestions or advice?? Anyone else have a similar problem?? thanks
i once bought an aftermarket distributer cap, and like an idiot I assumed the plug numbers on it were correct. they werent, car barely ran but i could get it to go even 55 mph, i scratched my head for hours and then started removing plugs to see which wire had no imopact, there were tow. switched them and bam. car purred like a kitten. may or may not be your problem. I was really annoyed that I did something that stupid and even worse it took forever to sort out.
gl. Kevin |
thanks for the advice but im pretty sure wires are plugged in right. haven't found problem yet gonna recheck sparks in each cylinder again for a faulty spark if any.
im sure youre familiar with the pull one then run to see if it affects, first place id start, especially with the na intake mani. just pull them at the distrib. and when you find one that has no affect, dont assume its the only one.
Kevin |
yup done that test too man each cylinder had same results from unplugging them one at a time. so far stuck in the same spot. I am gonna buy new wires anyways since i do notice there is some wear on them. Any other suggestion since i am gonna pull that intake mani off. Ive cleaned out the throttle and checked fuel system, still haven't found the culprit.
Possible dirty mas air flow sensor hot wire, bad ignition wires and plugs, leak in air intake tube. All of those will cause drivability and idle issues. Do you have a check engine light?
No CEL on. Gonna check the MAF tomorrow might be dirty considering the condition of other parts are in. New spark wires coming in tomorrow also hopefully it helps.
vacuum leak?
Originally Posted by khmersta
(Post 4902078)
Thanks |
kevro- your post about the mislabeled after market distributor cap was a huge help. I followed your suggestion and it solved my problem 100%. Next stop was the dealer $$$- thanks!
khmersta, did you ever figure out the issue? You said you replaced the distributor o-ring so maybe the timing could have been thrown off when you re-installed the distributor.
Originally Posted by TheMole
(Post 5376324)
EX: first cylinder should be cranked to TDC mark (top dead center) same time the spark should be hitting first cylinder spark plug- does that make sense haha. There should be a thread on this somewhere. yea my buddy was being un-aware of that so i had to back track his steps, and me being lazy to not put back the distributor cap back myself lol hope that helped. |
