DaveH T61...complete =) (pics!)
Old Aug 22, 2009 | 02:43 PM
  #46
Mortal300's Avatar
Mortal300
Its run of the GE!
Old Aug 22, 2009 | 03:17 PM
  #47
94_soarer's Avatar
94_soarer
Nice build mane!!! im feeling the kit....and tell those haters to fall back..ur manifold spools faster then the xspower manifold does...so tell then to relax!!
even tho im more of a xspower guy, who cares about how thw turbo manifold looks!! u cant see it wit the turbo in the way anyway..LoL
Old Aug 22, 2009 | 11:58 PM
  #48
TroySC300's Avatar
TroySC300
Nice man, I can't wait to start my NA-T build!
Old Aug 23, 2009 | 01:22 AM
  #49
RjBLayz's Avatar
RjBLayz
Lookin good bro! u gettin it tuned?
Old Aug 25, 2009 | 01:43 AM
  #50
DasBach's Avatar
DasBach
I was waiting for someone like steve to make a valid comment to quiet down the douchers who have nothing good to say about anything.
Nice build, I was wanting to do a NA-T but went 1UZ with a SC. Congrats!
Old Aug 25, 2009 | 10:42 AM
  #51
qksl2's Avatar
qksl2
Originally Posted by Ryeno
Well with that logic a honda civic with manual windows is better then an sc with power windows because it wont ever brake.
b) Proper grammar is anybody, not nobody.
I think you mean break. ;-)
Jad,
Great job dude, be proud of your car!
Ian
Old Sep 4, 2009 | 11:27 AM
  #52
dejacky's Avatar
dejacky
I'm in for the dyno results. Are you using a stock unopened 2jz-ge motor?
Old Sep 5, 2009 | 02:38 PM
  #53
Mortal300's Avatar
Mortal300
I aint puttin it on the dyno yet...gunna have FSR do gaskets n' studs...etc first. Got a long road ahead of me.
IC piping blew off the other day..DOH!
Old Sep 5, 2009 | 07:13 PM
  #54
dejacky's Avatar
dejacky
I also have the daveH base turbo kit and modified the rest of the setup to prevent intercooler pipes from blowing off . The freaky thing is with 2 solid pipes, the car spooled more consistently and even quicker than before
Old Sep 5, 2009 | 10:35 PM
  #55
stevechumo's Avatar
stevechumo
I see that you already wrapped a therrmal heat shield over the intake pipe right before the TB. That will keep the heat away, but to be honest with you, it's not that cosmetic. You may get a stainless steel heat shield made for your turbo size or a fiber wrap heat shield to completely block the turbine housing. Then you can leave the intake pipe smooth. The heat from the turbo will kill things around it soon enough. You can also paint the bottom portion of the intake pipe with thermal paint (somewhere between 1000-2000 farenheit paint), but leave the top part shiny.
Old Sep 5, 2009 | 11:22 PM
  #56
dejacky's Avatar
dejacky
Talking
Originally Posted by stevechumo
I see that you already wrapped a therrmal heat shield over the intake pipe right before the TB. That will keep the heat away, but to be honest with you, it's not that cosmetic. You may get a stainless steel heat shield made for your turbo size or a fiber wrap heat shield to completely block the turbine housing...
It's an old pic during installation process, so it doesn't clearly show the 2000 degree ceramic coating on the turbine housing nor the Turbo blanket. I'm well aware of proper heat protection management from the turbo setup given I've been na-t for several thousand miles, plus I used copper-heatwrap on the downpipe. But thanks for looking out for a fellow car enthusiast .
Old Sep 6, 2009 | 01:32 AM
  #57
stevechumo's Avatar
stevechumo
You're very welcome, my friend. I always love "NA-T" because it's out of the "Ordinar-Y".
Old Sep 6, 2009 | 12:37 PM
  #58
Mortal300's Avatar
Mortal300
Lol yeah i got the turbo blanket on mine too i just havent posted that pic!
Old Mar 26, 2011 | 07:41 PM
  #59
Mortal300's Avatar
Mortal300
Those who don't believe in DAVEH, this kit as been 2 years and running STRONG. Its a daily driver and I push it some days for my personal enjoyment, it runs awesome. *KNOCK ON WOOD* Only problem I've had is running too lean at idle but thats cus other problems I'm neglecting to fix.
I triple recommend DaveH's kit!!
Old Jun 18, 2011 | 08:51 PM
  #60
KahnBB6's Avatar
KahnBB6
Mortal300, a lot has already been covered in this thread but I am curious to know if the DaveH kit can be made to work with a stock Supra TT SMIC and a bit of custom piping as long as the standard boost level is not exceeded. I know you used a front mount as do most NA-T guys but I'd like to know if it would be adequate for the stock kit.
aceboogie6
GS - 1st Gen (1993-1997)
Nov 18, 2010 03:22 PM
carbongs
Sep 28, 2008 01:43 AM
Kyle Harty
Sep 27, 2008 11:02 AM
technol
Apr 29, 2006 02:35 PM
