Shern's W58 to R154 swap thread
Old Jan 24, 2011 | 07:35 PM
  #61
shern's Avatar
shern
Originally Posted by meangreen1
Nice thread shern. I saw it cost you about 2000. Could you give me a break down please. I just what like to know whats needed and whats not. THX
Super high level breakdown:
- R154 tranny - $400
- ACT clutch kit - $600
- JZ bellhousing - $310
- flywheel - $240
- MK3 prop shaft - $125
- shifter extension - $150
- MC speed sensor - $50
- misc parts - $200
Old Jan 24, 2011 | 10:58 PM
  #62
meangreen1's Avatar
meangreen1
Thanks that is helpfull
Old Jan 27, 2011 | 03:22 PM
  #63
xxtoobsxx's Avatar
xxtoobsxx
Stock sc300 or 400 rear drive shaft? I want to install my r154 to my sc400 soon!
Old Jan 27, 2011 | 03:23 PM
  #64
shern's Avatar
shern
SC300 will definitely work. Dunno much about the 400 shaft.
Old Feb 3, 2011 | 08:38 AM
  #65
sc300bigtx's Avatar
sc300bigtx
Originally Posted by SC51
^^ Haha good to know. I was torn between the street disc or the 6 puk. I decided to go with your combo, hows it holding up for you?
And Last question this https://www.clublexus.com/forums/per...54-swap-2.html post I found post #23 he says you have to bolt and torque down the pp bolts from the bell housing holes? Doesn't make sense is that true??
not sure if youve already installed but it will make your life easier if you number the holes on your pressure plate catty-corner so you know which to tighten next through the inspection covers
thats how i did it and made it much easier
Old Feb 3, 2011 | 03:42 PM
  #66
SC51's Avatar
SC51
^Thanks for the tip man. Is that just so you don't forget a bolt? Or it goes in a certain order?
Old Feb 14, 2011 | 09:21 PM
  #67
meangreen1's Avatar
meangreen1
Just to clairify, what version did you go? Bent shifter, or modded shifter housing? From you write up it looks like the first one. Hows the throw too?
Attached Thumbnails Shern's W58 to R154 swap thread-sc-20transmission_0003.jpg   Shern's W58 to R154 swap thread-r154-20extension.jpg
Old Feb 16, 2011 | 11:23 AM
  #68
SC51's Avatar
SC51
Hey My mount came with this extra metal thing welded in the middle of the mount do I have to remove that??
Old Feb 16, 2011 | 04:38 PM
  #69
Supraman24's Avatar
Supraman24
looks like an exhaust hanger
Old Feb 16, 2011 | 07:58 PM
  #70
good2go's Avatar
good2go
No, at least not for a W58. That one's just got the Toyota part number doesn't it?. I believe it's just slightly different than the Lexus one that doesn't have that tab. It fits W58's the same though.
Toyota = 12371‑46090
Lexus = 12371‑46040
Old Feb 16, 2011 | 09:25 PM
  #71
SC51's Avatar
SC51
good2go
Lexus = 12371‑46040
Oh well I'm installing it on a R154 and looking at sherns install pics the transmission drops below that point..
Old Feb 21, 2011 | 09:56 AM
  #72
LP1's Avatar
LP1
Default Shifters
Meangreen1
Those are my shifters not Shern's. We ran both, we didn't like the throw of the goose neck and the JDM extension, so repalced it with an extension we fabricated. Keep in mind the goose neck is a bent Supra stick not the JDM goose neck. The problem is the gooseneck is an attempt to align the stick with the opening in the Lexus making for a long an awkward throw (good chance of hitting the cup holder in 5th as I recall). The extension works great.
Old Feb 21, 2011 | 10:26 AM
  #73
LP1's Avatar
LP1
Default R154 Transmission Mount
I bought a W58 mount at the dealer and ordered a JDM mount for the R154. The W58 mount fits perfectly behind the V8 for the W58. The only difference between the two is about a 1/2" difference in hole location (ie no need to elongate the holes). We haven't fitted the R154 yet, the pictures shows the part number.
Attached Thumbnails Shern's W58 to R154 swap thread-jdm-part-no.jpg   Shern's W58 to R154 swap thread-jdm-r154.jpg
Old Feb 21, 2011 | 01:50 PM
  #74
good2go's Avatar
good2go
^^ That's the Soarer R154A tranny mount. I didn't think that US Toyota dealer could order those though.
edit: NM, I see you're in Canada
Old Feb 21, 2011 | 05:14 PM
  #75
SC51's Avatar
SC51
LP1
Damn that one looks a lot better, never herd of it mentioned before. But If anyone needs to know the exhaust hanger or w e needs to be ground down a little to work.
