Car wont start up
i parked my car in the garage yesturday when it started raining. i went out to the garage to start it up. the car cranks but wont start and iono wat is wrong with it. it started up last night i dont know why it wont start up now.
Turn the key on with out turning over the motor. Do you hear the fuel pump running? Your pump might be toast.
Originally Posted by 96sc300
(Post 4503114)
but my windows wont open either. what would cause that to happen? i cant even put the car to neutral either. |
bumppppppppppppppp
the fuel pump should turn on for only about 1-2 seconds then turns off by itself if you only turn it on w/o turning the engine on..listen closely if you still don't hear then replace the fuel pump.
Check your fuses first. If they all check out fine, then start looking at other things..
Originally Posted by schwarz
(Post 4503569)
Originally Posted by 2jzge-Moua
(Post 4503385)
bumppppppppppppppp
if your fuel pump isnt coming on, then a quick way to see if your pump is failing or faulty, is by jumping the FP and B+ terminal on your engines diagnostics port. You should hear the pump come on and fuel rushing in the lines if its working.
If its only working with a jumper and not working without one, then it is your Fuel Pump ECU, and I would recommend looking into bypassing the FP ECU with the 12v Fuel pump mod. |
Originally Posted by codetoad
(Post 4504250)
| All times are GMT -7. The time now is 07:34 PM. |
