My Billet 62 low boost dyno results....
Old 04-01-09, 04:22 AM
plex
1UZFE/2JZGTE
plex's Avatar
Originally Posted by TTSC3
Cherplex, I'm confused. How are you out of fuel? I remember tuning my car on stock injectors and AEM awhile back, and 540whp was 95% duty at 19psi on a 67mm turbo & pump gas. You shouldn't be out of fuel at 16psi on 62mm turbo. I've tuned a bunch of cars with similar setups and was able to make at least 500whp on stock fuel/stock injectors on pump gas. Something I'm missing in your setup perhaps?
I was thinking the same thing but I hit max boost close to 18psi on the streets so it's definately more than 433 and afr's are still decent at max boost. I will be doing fuel upgrade in a couple weeks so I'll get to see some better numbers on paper lol.
Old 04-01-09, 07:10 AM
TTSC3
TTSC3's Avatar
It still seems quite a bit off for stock fuel. I would make sure that you're getting good, consistent, voltage from your fuel pump, as you seem to be about 60+whp low. Was this on a Dynojet? Who was the tuner? Just curious...
Old 04-01-09, 07:29 AM
plex
1UZFE/2JZGTE
plex's Avatar
It's a dynojet and tuned by Brad Brooks.I have to double check on the fuel pump voltage etc..
Old 04-01-09, 07:37 AM
TTSC3
TTSC3's Avatar
Yeah, you need to be WOT and watch the voltage output on the pump. If it starts to drop, then there's your problem. Did you bypass the fuel pump ecu? Oh, and what about the fuel pulsation dampener? Is that bypassed as well? All of these will limit you severely.
Old 04-01-09, 07:42 AM
plex
1UZFE/2JZGTE
plex's Avatar
I will have to check into all that, I wasn't there when they did the dyno and I don't remember if the fuel pump ecu was bypassed. Thanks for the heads up.
Old 04-01-09, 11:14 AM
ConSynX
ConSynX's Avatar
I'd like to know more about the pulsation dampener. . .
i thought that was a 2jz thing, but want to make sure I don't have one.
If there's one of the SC300, it's part of the fuel lines themselves, correct? and please say they are on the feed line and not the return. . .
Old 04-01-09, 12:23 PM
TTSC3
TTSC3's Avatar
Well, he's running a USDM GTE motor, so he would have one in there. Some people have found it to free up some fuel, while some people say it didn't matter. Either way, 16psi and 430whp on a 62mm turbo is just not right. That car shouldn't be out of fuel with it being AEM equipped. I ran a 67mm turbo with AEM, on stock fuel, all the way to 540whp on pump gas. I think he might be seeing a voltage drop on his pump as pressure increases, so a fuel pump rewire may be in order. We'll see though.
Old 04-01-09, 01:56 PM
ConSynX
ConSynX's Avatar
woops, i skimmed the mods...i thought it was 1jz after seeing R154.
my bad.
Way to go all out on the swap, Cherp
Old 04-04-09, 04:45 PM
//LRD
//LRD's Avatar
USDM GTE motor
Soarer R154
Precision 6262 Billet, .68 a/r
Stock Injectors(550cc) with single Walbro.
Precision 850hp FMIC
3" DP/MP/Exhaust
AEM
Car made 433rwhp@16psi at 95% duty cycle on pump gas. Torque was close to 400 I think, I'm waiting on graph from ISP. I was hoping to push it to 500rwhp but was out of fuel. I'm ok with the results for now, my goal was only 500rwhp for now. Will focus my attention on the interior etc. Car pulls very smooth. I will do fuel upgrades soon so I can turn up boost some more so I can play around with a certain other white SC in the area lol.
433 @ 16 psi is pretty good for that size turbo..I have faith that you'll figure out the fuel sortly..... good luck
Old 04-04-09, 05:58 PM
JspecSC3
JspecSC3's Avatar
Sounds good! Cant wait for the video.
Old 04-04-09, 05:59 PM
edwinbong
edwinbong's Avatar
good numbers
Old 05-18-09, 01:12 PM
gldndrgn14
gldndrgn14's Avatar
at what rpm did you get full boost at 16psi? and was the turbo wanting to spool up more like on some?
Old 06-10-09, 02:48 PM
Ali SC3
Ali SC3's Avatar
Hey Cherp, how good is the tune with brad? you know, besides WOT.
Im planning on taking my SC there on monday. I have heard good things so far.
Old 06-11-09, 05:25 AM
plex
1UZFE/2JZGTE
plex's Avatar
Brad's one of the best tuners in the area IMO. Are you on stand alone?
Old 06-11-09, 11:58 AM
Ali SC3
Ali SC3's Avatar
yeah, got the aem ems installed, running on the basemap I can kind of drive the car.
I set up o2 feedback with my aem wideband so I am hoping to be able to get to the shop without blowing up anything.
deputy865
03-25-14 02:24 PM
jonboyb
01-17-14 05:09 PM
humble u2
08-02-09 04:43 AM
Teflon Don
05-23-07 06:59 AM
Quick Reply: My Billet 62 low boost dyno results....
