misc last wrap up wiring questions for gurus
hey-
im about to finish wrapping up the GE>gte (aristo ) harness conversion,
some questions on specific connectors:
where do i connect the reverse for w58 (2 wires) and speed sensor (3 wires)- are they supposed to be fed to aristo ecu or elsewhere?
e10 connector:
park neutral switch: R - does the trans switch connect to this?
#143 - pin 7
Red/Black from IK1 (Reverse lights) - trans switch connects to this?
Yellow from IJ2 and Red/Blue IJ1 (Speed sensor) - should i use VSS1 or VSS2 for speed?
also, on the alternator: there are 2 wires. black, white, yellow. - does anyone have a diagram where the yellow one should terminate? im guessing its guage cluster charge light?
Black/Yellow from IJ2 (12v switch, alt to charge batt)
e10 connector:
#143 - pin 7
