Blitz Nur Spec R Exhaust
Has anyone tried fitting the Blitz Nur Spec R exhaust for an MKIV Supra on a 95 SC300? I thought I read somewhere on here that it fits without modification, and that since it's for the Supra piping diameter is a bit larger than the one specifically made for the SC300. If you do have this on your SC300 could you post up some pics, or give a little mini review of what you think. Much thanks for your assistance.
1 Post
Got you covered. http://www.youtube.com/watch?v=nmtfV9D9MPM
http://www.youtube.com/watch?v=O0tx7XoOiTo
I took the silencer out, I can tell you that it does drone at 2500 rpms but thats about it, everything else it sounds like a pissed off I6. I love it, this model I have is the single exhaust exit from downpipe to tip, 3 1/2" piping all the way to the 114mm tip. It doesn't hang too low under the car and a custom arm was made to make sure it stays where its supposed to, nice and tucked in.
...anything else ya need?
rykwebb is that the Nur Spec or the Nur Spec R, and is it for the SC300 or the MKIV Supra. If it is the one meant for the Supra, did you have to do any modification to fit it on your SC300? Much thanks for your help, I'm ready to buy a Nur Spec R for my SC3, just not sure if I should get the one made for the car, or the one for the Supra. I'd rather get the one for the Supra since the piping is larger, but if modifying it to fit the SC3 is going to be a pain, then it might not be worth it.
1 Post
This is the Blitz Nur Spec R, for the SC300, roundabout 700 bucks, minor fabbing of an arm about 3/4s of the way toward the rear of the vehicle. Threw the silencer away long ago, I think it's a perfect note for my taste.
