problem engine light is on!!!
I was a week ago where the mechanic to fix me a leak of oil in the engine. he wash the engine and from there the engine light is on .not yet been removed the light. which will be the problem?
Yes, however this is only for OBDI vechicles (SC years 92-95). OBDII needs a scan tool in order to pull codes. Any auto parts store can do this for free.
For reading the CEL flashes there should be a set on one flashes each seperated by about half a second or so. After that there should be a small gap of about a second or so. Then another set of flahses will go off. If there are multiple codes there will be about a 2-3 second delay in the flashes.
Example: with the paper clip in mentioned above, blink-blink-blink small gap blink-blink-blink-blink will mean code 34. If you do a search on goolge on Toyota OBDI trouble codes you can then decipher what the code is saying and what the problem area might be. This might not be 100% right as i have only done it once on another vehicle (mine is OBDII) so someone correct me if i've missed anything.
EDIT: link to codes and how to retrieve them: http://www.troublecodes.net/Toyota/
hey man whats up!! thanx a lot man....1 more question where is the EFI fuse located on my car? lol i want to reset the ecu....
