please help me:clutch problem
please help.
i have a 5 speed sc300 and never had a problem before, but now sometimes when im driving, my clutch pedal wont come back, i have to pull it with my feet or sometimes i have to pull it with my hand. my friend told me to check the clutch fluid, but it seems ok. Any help will be appreciated, thanks |
Originally Posted by o_mtz16
(Post 4107850)
please help.
bleed the system first, but that probably means there is a small leak somewhere in the system already. Check all you lines for leaks and if none are found you'll need to replace either the master or the slave cylinder.
i would think its your slave if your clutch isnt poping back up but your gear engages.
i used to have a same problem. i just rebuilt my slave and worked good as new. now my problem has came back a week ago haha. looks like most definitly have a leak somewhere, sadly. im going to look for a new slave cylinder this time and inspect all lines. do it right, do it once. |
thanks guys for your help
