ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   here we go again.your info is appreciated. (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/384647-here-we-go-again-your-info-is-appreciated.html)
n8doggdago Oct 10, 2008 12:42 PM
im having problems with my sc300...again...my ride is doing this.....:
when i come to a stop then accelerate it bogs out then jolts when it is shifting it jerks as well...i just replaced the tranny 2 weeks ago...and i am afraid its the ecu...maybe the throtle control sensor? what do you guys think?
Sup2jzgte Oct 10, 2008 12:43 PM
How much tranny fluid did you put in?
n8doggdago Oct 10, 2008 01:22 PM
the tranny fluid is good to go....the tranny is good i took it to my uncles shop and it has a 3yr warranty...when i gas the car it lags then it jumps into gear...will the ecu make your car do this?
SHOLEXMAN Oct 10, 2008 05:51 PM
I haven't heard much about the ecu being at fault. Is it the same torque converter or has it been replaced? Was a rebuilt tranny or used one dropped into the car? Did you check the correct level of fluid while it was running in park? There could be a possibility that you might have a low or high fluid issue. If it is a used tranny the clutch packs are possibly going bad. The solenoids might be faulty. Is there a check engine light? Check these items out cause that tranny might be garbage. Updates please...
