Documentation of R154 swap w/ pics
Old Mar 10, 2008 | 11:58 AM
  #31
vipsoarer's Avatar
vipsoarer
I will agree to disagree. so some people have done it with success, but do it at your own risk!
Old Mar 10, 2008 | 07:01 PM
  #32
adam8103's Avatar
adam8103
Thanks Guys I'll probably go with a lighter 1jz flywheel ...
if i am correcte this part is needed only if you hav a automatic tranny before?
"Clutch master cyclinder from MKIII (turbo or non, doesnt matter)"
i have the sc300 5speed i probably can keed my master cylinder?
and the slave will probably come with the tranny
Old Mar 11, 2008 | 08:42 AM
  #33
vipsoarer's Avatar
vipsoarer
No matter if you are a 5 speed now or an auto you will need a flywheel that works with the trans, be it a 1jz flywheel or (as stated above) a redrilled 2jzge flywheel (have a machinist do modifications at your own risk).
you can use your master cyl from the sc and the trans will most likely come with the slave, if not go to advance auto, napa, autozone, etc. and they should have them in stock.
Old Mar 11, 2008 | 07:21 PM
  #34
adam8103's Avatar
adam8103
thank you.. sorry i edited my last post.. i didnt wrote it correctly i knew that i needed the flywheel, i was talking about the master cylinder that was a part that needs to be change if you are not 5 speed.. and you confirmed it thanks
Old Mar 19, 2008 | 06:14 PM
  #35
97-SC300's Avatar
97-SC300
that kind of looks to close to the brake pedal.
Old Mar 30, 2008 | 09:14 PM
  #36
Cleanshots's Avatar
Cleanshots
so to mount the r154 the w58 cross member can be used?
Old Mar 30, 2008 | 10:27 PM
  #37
lemmiewink's Avatar
lemmiewink
Tranny mount from the w58 will bolt on to the r154 I believe. As for crossmember..... i have both the auto crossmember and a w58 crossmember. They look EXACTLY the same. Same length, width, height and bolt pattern... But I haven't really measured it, I just sort of eyeballed it and did a side by side comparison to it while I was under the car unbolting my auto tranny.
I can confirm that the w58 crossmember will work, since of course you can use the w58 trans mount.
Old Apr 1, 2008 | 01:02 AM
  #38
Cleanshots's Avatar
Cleanshots
trans mount meaning the cross member for the tranny? that attaches it to the frame of the car?
Superjatt
Jan 17, 2010 08:24 AM
diesel4368
Nov 3, 2008 10:33 PM
