ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   would this be a symtom of a bad injector? (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/335293-would-this-be-a-symtom-of-a-bad-injector.html)
dumdumgreg Feb 10, 2008 08:25 PM
I've noticed my EGT's being pretty high latley
around ~755 while cruising (in the past it was around ~670)
Also my AFR looks funny,
while holding the car at 3,000 rpm or any set rpm for that matter on a flat road at a steedy speed. The AFR would jump between 13.5 to 14.7
In the past the AFR oscillation was maybe a .3 variance.
Mind you this is at a set speed and rpm on a flat road...
Seeing these 2 symptoms makes me suspect a clogged/bad injector. I'm just making an educated guess here...
what do you guys think?
Luke_in_SD Feb 10, 2008 08:53 PM
what kind off millage are you getting?
dumdumgreg Feb 11, 2008 09:16 AM
Quote:
not sure, I usually never pay attention to it as it's hard for me to get an accurate mesaurement here in the city.
Daytime driving with stop and go bumper to bumper traffic really throws it off alot
lexforlife Feb 11, 2008 10:15 AM
are u boosted or still stock
755 f on egt is low , i am boosted and while cruising normal egt in vacum only is around 900 to 1200 degrees
dumdumgreg Feb 11, 2008 01:33 PM
opps forgot to list my temps as Celsius
so thats like ~1400 F
and yes I'm boost,
dumdumgreg Feb 13, 2008 07:07 PM
bump
anyone?
