JDM 2JZ-GTE Twins
What's the safest max boost I could run them to? I know they're not as durable as the USDM ones. I was planning 14 psi daily driven and 18 psi occasionally.
Rage, that 18psi is absolutely not realistic....you'd be very lucky to see 18psi more than a few time before JDM ceramics turn into shrapnel and you loose all their wonderful early spool and tq. Parnzen is correct and for a reasonable safety margin, the number not to exceed might barely be like one bar on JDM's
Also, there there is much better and accurate info on your question on SF. Specifically one example: http://www.supraforums.com/forum/sho...=ceramic+boost
Abelo
Apr 6, 2011 05:14 PM
brian lin
Apr 27, 2006 03:26 PM
