voltage issues
im new to cl and i have a 1995 sc300 which i bought about 2 weeks ago i was driving and the battery light turned on i know what that means the alterator went bad so i removed the one of my project car and its charging 12volts and it drops to 11,10 volts when i turn the lights , hazards,ect on i have installed 3 other alternatos with the same result please help me maybe somone else has experienced the same problem...to view my project go to www.cardomain.com/ride/2696894 let me know what you guys think about it it runs and drives thanks
Have you tested the battery to make sure it's good? Where did you get the alternators from? I've seen 3 consecutive reman alternators that were no good before. All depends on where you get them from unfortunately.
edit: Also make sure that your grounds and battery terminals are still good. |
Fix your loose or corroded grounds.
| All times are GMT -7. The time now is 04:22 PM. |
