1998 Sc 300
Old 05-17-07, 12:16 AM
brian1258
brian1258's Avatar
Default 1998 Sc 300
Just pick this up.. what kind of oil you guys are using?? thanks
Old 05-17-07, 02:12 AM
RedPhoenix
RedPhoenix's Avatar
5w/30. I run Mobil 1 Synthetic
Old 05-17-07, 05:41 AM
c2ispy
c2ispy's Avatar
same here, 5w-30 mobil1 synthetic all the way. But, i might tryout royal-purple since I hear people swearing and raving about it.
Old 05-17-07, 06:36 AM
RedPhoenix
RedPhoenix's Avatar
i was thinking about it, but i probably wont see any difference. now if the oil WAS purple, id so get it.
Old 05-17-07, 07:40 AM
StiCk3
StiCk3's Avatar
5W-30, castrol non-synth. no probs.
just out of curiosity for the synthetic guys, how often do you change the oil? Do you get those extended milage oils (10,000-15,000 miles)? and how long have you been using them? srry if this is a bit of a thread jackin...
Old 05-17-07, 08:01 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
Heck no!
I use Royal Purple and I still change oil between 3000-4000 miles. No sense taking that chance for a few dollars saved.
Old 05-17-07, 08:33 AM
$C300
$C300's Avatar
royal Purpal or Red Line < proven to be the top two, mobile on is actualy not that good. There was the test and the chepo 79c stuff beat mobile 1 after hearing about this i switched to royal purpal from Mobil 1 and change it every 3000K.
Old 05-17-07, 09:27 AM
TheMole
TheMole's Avatar
I don't race or drive hard so I just use Toyota oil.
Old 05-17-07, 11:28 AM
RedPhoenix
RedPhoenix's Avatar
I do 7k miles with Mobil 1
Old 05-17-07, 01:23 PM
kyoso23
kyoso23's Avatar
3-4k w/mobil1
Old 05-18-07, 05:50 AM
StiCk3
StiCk3's Avatar
Originally Posted by mkorsu
Heck no!
Personally i disapprove of those "extended milage" oils. Heard that they do more harm than good. Didnt know what the opinon was here, but now i do. thx though....might be pickin up some purple if i decide to go turbo......
Old 05-18-07, 07:40 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Please show me where this test is...
www.bobistheoilguy.com
Mobil1, Castrol, Redline and Royal Purple ALWAYS get the best UOA's (not that I care a ton about UOA's, they just back up what I've always thought and done) If you really follow the UOA stuff, the German Castrol oil (it looks kinda green) is actually the "best"
For me, it's Mobil1 every 5000 miles... (10W-30)
The only difference between standard oil and extended performance is the amount of detergents in the oil itself... Personally, I use extended performance, and still change it every 5000 miles (or prior, depends on my mood)... In my wifes car, I use Castrol Syntec 10W-30 and do the same, 5000 mile intervals...
Old 05-18-07, 07:54 AM
sc250tt
sc250tt's Avatar
i jus bought mobil 1 10-30 clean 5000 form walmart for 10 bucks ,i was gonna return it and get synthetic 5-30 .is it safe to use the clean 5000 for a 1j?
Old 05-18-07, 08:11 AM
CleanCL
CleanCL's Avatar
I believe mobil1 recently changed their formula or something along those lines that somewhat degraded the quality. I personally don't know of any specific tests but this is just what I've heard through the grapevine.
mitsuguy
mitsuguy's Avatar
yes, again, its just the level of detergents that changes between them...
$10 for how much oil? a gallon? if so, that is SUPER cheap!
Quick Reply: 1998 Sc 300
