sc400 stay stock or 2jzgte
hi i am new here i started with honda and i worked my way up to this lex. Basically i got a sc for dirt cheap but from what i am told it needs a motor. im trying to weigh which one costs less. I have yet to see an sc with a 2j around me I am thinking the auto tranny might be toast too so thats why i was considering a swap i have a couple of questions about the swap i read almost every thread on sc400 first so i did search and there is alot of small pieces of info so i figure i might as well fill in the blanks
What parts for the 5sp conv do you use (pedals shift linkage)?
What is involved in the wiring for this? Does the 2j harness connect to the stock firewall connector? do you have to repin the ecu connections?
can i use the sc300 or supera mounts to get it in?
can i use a supra 5sp trans with a 2j? and do you have to beat in the firewall to fit it?
can i retain a/c?
How does it work with the turbo fittings and the down pipes? Do supra parts fit for all of that?
what about the drive shaft?
can i retain a/c?
