Who has installed a wet/dry Nitrous on the 300?
Alright, this is where I sit right now. I can't afford a turbo, but I want to go down that road one day. So I want a wet kit. My question is what kinds of problems did you guys run into installing the NOS,Zex or any other kit? I plan on runing the 10lbs bottle with adjustable from 55-75hp. So hopefully I won't have to put in the bigger fuel pump. Also how do I go about hooking up a SAFC after I get the kit installed? Any special tools that I might need. Type of spark plugs I should get?
Thanks guys.
Thanks guys.
Banned - could not follow forum rules
100hp dryshot would be a great option for you...All you need is a walbro high flow fuel pump just for safety...Hook it all up, dry system you don't need to tap into the fuel line...Dry is easier and safer for a small nos shot like that.... You won't even need to enrich the fuel mix on that size shot....Good luck...
Yeah, with less then a 100hp shot a hi flow fuel pump is not needed...Also those nos bottles will last forever, too.... Go for the 100-150hp and feel the rude power, that is what I suggest...A 50 shot is like a tease.....like a quick kiss on the cheech from an average chick while wearing beer goggles and a 150 shot is like scoring a home run with the prom queen on prom night.......Just my take... .
thanks for the reply guys, Jibby if a 75 isn't going to be enough I guess I will do the 255 pump for it and do the 100. What company sells the best kit for cheapest? ZEX, NOS? Any propblems installing it?
