Where can i find motor mounts?
My motors mount just went the other day so i want to know where i can find stock mount for a 95 SC300? thanks in advance....
:uh: the dealer? toyota would be cheaper... go with the post 98 supra mounts.. they work.. i think ;)
From the dealer...do not put in used parts for this...not worth it.
Ryan |
how much u guys think they run for?
Tony |
that depends on where in florida you are, and who you know ;)
if he knows you then the price is double :D
rockauto.com may have them. I've ordered parts from them before for pretty cheap.
Is anyone here sure of the supra crossover on the engine and trans mounts? My local dealer said that the motor mounts changed midproduction in 95. Any thoughts?
aww man i wish i remembered... but it goes like this:
our mounts will work with mk4 supra mounts... but heres what i don't remember... - you have to either use the brackets along with the mounts if its pre 97 OR - you can just buy the mounts by themselves if its post 97 Or it can be the other way around with the years. PM Steve on the supra board.... he can cross reference the part numbers for you last time i checked... everything including a new tranny mount was going to be like under 200 |
our mounts will work with mk4 supra mounts... but heres what i don't remember... - you have to either use the brackets along with the mounts if its pre 97 OR - you can just buy the mounts by themselves if its post 97 Or it can be the other way around with the years. PM Steve on the supra board.... he can cross reference the part numbers for you last time i checked... everything including a new tranny mount was going to be like under 200 Does anyone have any more solid info than this? Both my mounts were shot after pulling the motor and I need to replace them. |
where in fl are you? i can help u out give me a call whenever 904-465-3822
Supra Mounts from 97-98 work fine... i didnt have enough time to buy them and had to buy actual lexus dealer mounts.. that cost a pretty penny..
u can get the SUpra mounts for like 75.00 or so..i was about to buy them but thought ill hold off on it. when i pulled the engine i had only a set amount of time to swap and get the car out the shop so didnt have enough time to get the supra mounts since it was thanksgiving week. ended up getting lexus mounts.. |
Do I need to purchase new brackets or just the mounts themselves?
12360-46111 Insulator List 71.68 Cost 53.00 X 2 Is what Curt quoted someone on SF.C |
no brackets are needed if you use 97-98 mounts...
if you want TRD mounts u will need brackets and Mounts |
:uh: Would the car idle as smooth with the Supra mount???
| All times are GMT -7. The time now is 08:42 PM. |
