starting up help!!
Old Feb 13, 2005 | 11:55 AM
DontHateSc's Avatar
DontHateSc
Default starting up help!!
Hello all, it has been awhile since I have posted here. My problem is that my 95 sc400 will not start! I suspect its the starter because I have gone through 3 batteries in the past 6 months. The radio works fine and all power is on, but my car will not start. The car either doesnt have enough power to start or the starter doesnt work. But I can jump the car for it to work fine. Any help is appreciated, thank you very much to all those who do help.
Old Feb 13, 2005 | 12:57 PM
KidPandJ's Avatar
KidPandJ
If you're mechanically inclined you can take the starter off and take it to AutoZone/Pep Boys/ Advanced Auto and they'll test it for you. Not that big of a deal. They can test your alternator and battery too.
Old Feb 14, 2005 | 03:31 PM
Dx3's Avatar
Dx3
Dude,
You know where the starter is on a 400?? Not a fun or easy task! If you do remove your starter I would replace the solenoids regardless as the starter is such a PITA to get to.
As for the starter problem - are you getting any clicking or anything? More info?
Good luck,
Jonny
Old Feb 14, 2005 | 04:05 PM
KidPandJ's Avatar
KidPandJ
Originally Posted by Dx3
Dude,
Good luck,
Jonny
......"if you're mechanically inclined" is there for a reason
Old May 10, 2007 | 09:38 AM
Aaronsc400's Avatar
Aaronsc400
Default im having a sim problem
my car wont start i cant seem to disarm the alarm thats what i think because i cant use the key in the door i have to put it in the ignition to disarm it but it wont start?
Old May 10, 2007 | 09:50 AM
morris's Avatar
morris
Friend if you can jumpstart the car then the problem is not the starter.
I would look at the alternator as my first stop
Old May 10, 2007 | 08:43 PM
Aaronsc400's Avatar
Aaronsc400
helleo all/thanx for the replies i cant jump start it what happens is i have to have someone sit in the car and hold the key in the start position and then i take the positive or negative cable off and tap it to the battery and then the starter will start clicking and then after awhile it will then turn over i think its the factory alarm any answers? thanx im new here...
Maik04
Mar 10, 2015 07:57 PM
poplady
Jun 30, 2014 02:46 PM
OneJay
Aug 15, 2011 03:24 PM
denvergs4
Oct 30, 2007 09:26 PM
sockfocks
Maintenance
Jun 17, 2006 07:06 AM
