Misifiring... Electricals?
Mortgage Slave
Hi guys, need some info desperately!
My car's been in the shop for the last two weeks or so now, getting the turbos changed (as one's blown) and there's a stupid misfire in the car. Trying to diagnose what the friggen problem is. Now, the spark plugs have been replaced (they only saw 7000kms of driving or so), the coils and ignitor have been tested (turned out A OK), connectors have been replaced to new ones... can't seem to find the problem? It seems whenever a coil is connected up to cylinder 5 there's a very minute spark (compared to the other cylinders, where it's firing perfectly). Engine's a 1JZGTE.
So where do I look now for clues? Could it be a dead ECU? Does it sound like an electrical ghost? Hoping it's not the wiring otherwise it's gonna be a pain in the proverbial ****...
Jose
Jose
If theres a smaller spark than the other cylinders than it has to be the something on that line from the Ignitor to the spark plug. I would try swapping coils, with the same spark plug in there. Check the output of the spark plug on whatever cylinder you swapped the cyl 5 coil to and compare. If the coil does the same on the other cylinder, then you know its the coil. If it doesnt, and cyl 5 still has weak output then look into the spark plug or the wires going to the ignitor. The ignitor should have just a single channel burnt out on it, but it may.
Mortgage Slave
Thanks a lot for the suggestions guys, will do!
So from what I can see from the replies, there could be something wrong in the wiring between the ignitor and the coilpack itself? The mechanic swapped coils from the other cylinders (which are firing perfectly), it only happens on cylinder 5?
prjctSC300, leak down test? Please explain. My car's never been in so much ish before hehe...
Thanks
Jose
Thanks
Jose
My understanding of the stock ignition system is that the ECU will send out a signal to the Ignitor based on a Crank Angle Sensor. The ignitor sends out a base voltage, around 200-300v maybe which gets amplified at the Coils, which are independant of each other and fire two at a time. Im not ruling out some bad engine work, but it seems like its just in the ignition system. Have you checked the plugs recently for more fouling on #5?
Mortgage Slave
Cheers
Jose
Mortgage Slave
I was speaking to the mechanic today, he said that my ECU was throwing up some really whack voltages and signals... anyone ever had this problem before?
If your ecu got wet i can see it happening. Electronics are very strange sometimes. It shouldnt be the Crank Angle Sensor since it wouldnt affect just one cylinder. I dont know how the ECU fires the ignitor either, so it may be a plausable idea. Its pretty easy to pick up another ECU and throw it in there fast though
Mortgage Slave
Update: Tried switching the following... (between my car and a donor (ie. a buddy's) Soarer 2.5GT)
* ECUs
* Ignitors
* Coilpacks
... to no avail. Now I'm relaly thinking it's the wiring somewhere that's f*<Ked up.
* ECUs
* Ignitors
* Coilpacks
