Misfire
I have just replaced the waterpump, 2 bearings and the timing belt. After putting everything back together, I can't get it to start. I think I am not getting fire to the spark plugs.
Any suggestions. |
Timming belt?
If your replaced it and are having mis-fire you might have put the belt on a few teeth off... This will cause the whole combustion process to be off and cout possibly damage your valves... I'd put the cams to Top dead center and check the crank to be sure its all where its supposed to be... Hope this helps... Good luck with the car buddy... Bryan
Misfire
Thank you very much for your reply Bryan.
Ben :D |
Your welcome...
Just hope you get your car running.... Keep us updated on what the problem was... It will probably help others as well... Bryan
