auto to getrag 6 speed
Old Oct 5, 2005 | 04:59 PM
  #31
DETUNED's Avatar
DETUNED
THis is how much I cut from my auto.
You can see where the auto shifter hole is (all the way torwards the back of the car). I had to cut it this much just to clear the getrag.
Hope this helps.
Old Oct 5, 2005 | 05:22 PM
  #32
jpvarghese's Avatar
jpvarghese
Default 4 detuned
When doing the conversion what parts from the 5-speed are similar/can be interchanged with the 6-speed Getrag?? What new partsw must be replaced? Detuned, did you have to change the sub-tunnel as well? As in the Supra does the manual sit higher than the auto in the SC as well; hence the sub-tunnel work? It's almost impossible to find 5-speed parts used; especially the interior modifications; where can I find this stuff for cheap? Since there are alot more N/A Supra parts around; are there any for the manual conversion that are interchangable?
Old Oct 6, 2005 | 05:33 AM
  #33
DETUNED's Avatar
DETUNED
the only different mod that I had to do between the 5 speed and the 6 speed, was cut that hole a little larger, since the getrags (a-arm) that holds the shifter, sits a little higher. I made my own plate to cover it up, as shown in this pic. (it's not sitting straight in this picture though). everything else is the same. You will need the 6 speed shifter fork and slave. other than that, there isn't much difference.
You can get the parts brand new from lexus for cheap. IIRC, I payed $42 for the brake pedal and $32 for the clutch pedal. And got the other parts at cost as well.
Old Oct 6, 2005 | 06:50 AM
  #34
jpvarghese's Avatar
jpvarghese
So instead of getting the 5-speed sub-tunnel, you modified the auto one? Ok I am planning to get a W58 soon with all the parts for real cheap:
thats:
RPS stage 3 clutch (blue, 6 puck)
Fidanza rebuildable aluminum flywheel
slave cylinder
tranny
shifter
perch
tranny rear mount
Since the W58 are abundant in the N/A Supra world; I think its cheaper to convert to the 5-speed and upgrade to the 6-speed later on. So I'm assuming you've been using everything from the 5-speed; except for the V160 transmission, driveshaft, shifter assembly, rear-end, slave cylinder. Is the auto driveshaft compatible with the W58??? Thanks in advance man; I think we should sticky this damn thing!
Old Oct 27, 2005 | 12:05 AM
  #35
jpvarghese's Avatar
jpvarghese
DETUNED; you didn't have to do any pounding on the sides of the auto subtunnel when you threw in the 6-speed right? I know you cut the hole a little longer, but was that all you did for it to fit?
-Justin
Old Oct 30, 2005 | 09:07 PM
  #36
88supramki's Avatar
88supramki
not to sure about that assumption that it will be cheaper to convert later. most likely you'll end up paying more in the long run because there are a few differences between the getrag and the W58. plus, the getrag isn't cheap by itself
Old May 19, 2019 | 09:34 PM
  #37
WEST1815's Avatar
WEST1815
Can you please respond to me I want to do the same with my 1996 SC 300 but many mechanics here say it's not worth it; I think they don't know how and I feel if I can think it; it must be possible. Is this very expensive?
Old May 20, 2019 | 02:32 AM
  #38
gerrb's Avatar
gerrb
Super Moderator
West1815 -welcome to clublexus .
This is a 15 year old thread so the members on this thread might not respond.
At this point in time , it is indeed a very expensive exercise to go into a 6 speed Getrag swap. Just the Getrag 6 speed at second hand condition will be in the vicinity of $6k IF EVER you find one. Then you need the drive shaft , the right differential. Depending on power a very expensive clutch and pressure plate. The 6 speed axles and some other small things. Assuming you are onlly getting stock clutch and pressure plate, You will be at $12k at least without labor. Add a twin or triple clutch , you will be hovering at +$15k
Indeed it is a very expensive auto to 6 speed conversion project . Do some more readings and you will find that there are some other cheaper options.
Good Luck
Old May 20, 2019 | 05:20 AM
  #39
WEST1815's Avatar
WEST1815
Thank you so very much I guess that settles that dream!
Old May 20, 2019 | 06:24 AM
  #40
oldManTan's Avatar
oldManTan
get a CD009, much newer 6 speed that handles quite a bit of power as well and only costs $300-$500.
cost of trans only, adapters, custom driveshaft and flywheel and you're at $2,400 already.
source: i've done it.
Rytzrap
Performance
Feb 13, 2013 08:36 AM
BALConnell
SC400 / 300 Classifieds
Oct 11, 2009 02:16 PM
zaquanh
IS - 1st Gen (2001-2005)
Nov 27, 2006 08:59 AM
sxylxy
Aug 9, 2006 06:31 PM
hemogoblin
Jun 26, 2006 03:52 PM
