Throttle body position sensor voltage output
Old Aug 3, 2004 | 09:30 PM
2JZSoarer's Avatar
2JZSoarer
Default Throttle body position sensor voltage output
does anyone know how many volts does a SC300 TPS put out when it's wide open????
I've search..not an answer anywhere...
Old Aug 5, 2004 | 06:23 AM
Choritsu-shi's Avatar
Choritsu-shi
not volts... ohms. At WOT, using an ohmmeter, measure the resistance between terminals;
"VTA" and "E2" which should be 2.4- 11.2 k ohms
-and-
"VC" and "E2" which should be 3.1- 7.2 k ohms
Sensei
Old Aug 5, 2004 | 07:29 PM
aliga's Avatar
aliga
Former Sponsor
I did the sensor check on the afc, and got the following values:
sensor check:
@ 0 throttle = .5 volts
@100 throttle = 3.75 volts
Old Aug 8, 2004 | 03:31 PM
2JZSoarer's Avatar
2JZSoarer
o..well..I measured it and I almost got 4 volts...it's like 3.8, 3.9....o well..thanks...I greatly appreciate yall's help
dlamb89
Jun 13, 2015 04:22 PM
frankjames
May 12, 2009 06:00 PM
want sc300
Nov 8, 2007 05:04 PM
LB Lex
Maintenance
Jan 11, 2003 03:19 AM
