Sc 400 limp mode
Old Jul 29, 2024 | 05:22 PM
jimboboss302's Avatar
jimboboss302
9th Gear
Default Sc 400 limp mode
My 93 sc 400 is having issues with a 2k rpm rev limit and the only codes being thrown are for the tps and egr system, I’ve heard the ecus go out so I’ve replaced mine 3 times with used computers and have continued to get a dysfunctional vehicle, have I gotten 3 bad ecus or is something deeper going on that I’m not seeing? Possable wiring issues that keep blowing the computer?
Old Jul 30, 2024 | 06:47 AM
t2d2's Avatar
t2d2
It's possible a bunch of used ECU's would all be bad, but highly unlikely they would all have the exact same faults, considering how wide ranging the symptoms of ECU failure are. So, I would assume your TPS and EGR actually do need inspection.
Old Jul 30, 2024 | 06:49 AM
jimboboss302
9th Gear
I know it has an egr delete so that is understandable but could the tps really cause a limp mode running condition?
Old Jul 30, 2024 | 06:51 AM
t2d2's Avatar
t2d2
I wouldn't think so, but it's pointless to chase hypotheticals until dealing with the known issue.
I also don't think that's limp mode. Limp mode throttles power at any pedal position, rather than just capping RPMs. If the TPS is way out of adjustment, I could see that maybe limiting RPM range.
Old Jul 30, 2024 | 06:53 AM
jimboboss302
9th Gear
I have a box full of random sc4 sensors in the garage back home. When I get home I’ll try a few on and see if I notice a difference in running condition.
Curated Content Editor
Aug 7, 2020 11:59 AM
dgardner
Feb 1, 2005 08:22 AM
whosdady
Dec 14, 2002 08:13 PM
