Alternator Not Charging Battery???!?!
Old Jun 4, 2024 | 04:04 PM
malc300's Avatar
malc300
1st Gear
Default Alternator Not Charging Battery???!?!
If anyone could give me some advice on this i would greatly appreciate it
i have a 97 non vvti sc300 and ive run into an issue where the alternator does not produce voltage at all and im honestly stumped ive checked all the wiring related to the charging system and everything seems to be working properly according to my multimeter
i also checked all the fuses related to the charging system and put a remanned alternator in and still nothing. Now i know these denso alternators are notorious from being faulty out the gate however i had the alternator bench tested at a local shop and everything checked out
i just want to know what im missing i dont want to keep dumping money into stuff that isint going to fix the problem
Old Jun 6, 2024 | 09:40 PM
Arsenii's Avatar
Arsenii
Hello,
Are you sure you got Genuine Denso alternator?
Describe the steps you went through up to this point in details to avoid a lot of repetition. Here is a thread describing the troubleshooting steps, other than that, below is a video going over some of the similar procedures, as well as some extra ones, which may be useful.
Hope this helps and best of luck!
Joldas
Dec 19, 2019 05:50 AM
dontcallme
Oct 14, 2019 07:16 PM
Catalina45
Oct 4, 2018 08:17 AM
rx04Lexus
Apr 30, 2010 02:30 PM
Neo
Maintenance
Nov 30, 2004 06:29 PM
