Enform vs Car Play
Enform vs Car Play
Just came back from the dealer. Almost all the new cars on the showroom had Apple Car Play installed. I asked about an upgrade to Enform 2.0 since I have a pre October 2019 NX 300. Was told that probably no upgrade from Lexus since all the cars now had Apple Car Play.
There is another thread here about Lexus upgrading 2018 and 2019 models.
"Lexus remains committed to enhancing our in-vehicle multimedia guest experience. We are currently conducting an internal trial for Apple CarPlayŽ compatibility in some 2018 LC, 2018 LS, 2018/19 NX, 2018 RC, 2018/19 RC F, and 2019 ES (non-navigation). At this time, we do not have any additional information we can share but anticipate providing further details to the applicable guests in Summer 2019."
There many times when the Nav System doesn't work at all. Apps greyed out Scout Gps not functioning.I can go into details if you wish. This has been an on going battle
since I purchased the car in October.
Decided to discuss the issues. The first problem is with Blue Tooth. Car's blue connected to my wife's iPhone even though she is not in the car. When I get into the car blue tooth does not recognize my iPhone. Apps greyed out. It is possible that even though her phone is in the house it is not far away from the car to disconnect her phone from the blue tooth connection in the car. Went to the dealer, about fifteen miles away, by the time I got there my phone was reconnected at the apps were activated. Second issue is with Scout GPS. Map function not working eg turn by turn. I was using both USB ports. First one with my iPhone and the second my iPod touch .As soon as I completely disconnected the iPod touch map function returned. I discussed this with an engineer and he suggested that there may be a power issue involved when both USB ports are engaged. Any ideas? I also wonder if Car Play will have the same problem when both ports are engaged.
I believe there is a setting to prioritize which phone connects to Bluetooth when both are in the car.
As far as the USB ports, I havent checked but one is probably high speed(more power) and the other is not.
Can you load the music on your iPhone and skip the iPod?
Checked about prioritizing the phones via blue tooth and you are correct. Looked at the USB ports they are the same. However on page 111 of the Navigation and Multimedia System Owner's Manual it says the following:If two devices are connected to the USB ports, depending on the devices, both may not be able to be recognized by the system at the same time. That's the answer. Nobody at Lexus ever stated that. Thanks for you help.
Blue tooth is a mess and unreliable. Worked great for a while then kept losing the BT connection. I belong to a Mac User Group and our guru told me that the BT on most cars is not very good. So I have this unreliable problem with it. Rebooted the phone, connected and disconnected my iPhone and finally got the Apps to work again.
I have the 10s Music is not a problem It is using BT with Enform 2.0 The Apps are greyed out eg they don't connect. After going through the above mentionioned gyrations they become activated and I can connect Scout GPS
Ah. I think you need the app running on your phone. I dont use any of the apps in the NX.
