NX Car Paint Cracking
Hi there, I have a 2016 NX 200t that I purchase new a little over 2 years ago. Today, I noticed a spot about the size of a quarter on my front hood that shows paint cracking. Is this normal to see paint cracking so soon? Could this be a bad paint job from the manufacturer? Would the dealer be able to help fix this if it is? Thanks
No, this is not normal.
Often, cracks that develop in paint are the result of improperly done paint repairs. Even with cars that are bought new, it is not uncommon for paint repairs to have been done as a result of damage done during transport or while they are on the dealer's lot. Without being able to actually see the cracking that you are talking about, I can't say that this is what happened in your case, but it is a possibility.
Impact from a stone or other object can cause cracking, too, but, from you description, it doesn't sound like that is the case on your car.
Can you post a picture?
ukrkoz (09-23-18)
The pursuit of F
Think back if you might have had a bird dropping. If it sat there for a while baking in the sun, it could have etched the clearcoat, weakened the paint, and now cracked...
Good luck.
Good luck.
What I wanted to see was the nature of the cracks.
If it was from impact, I'd expect to see a single crack or, maybe, a couple of cracks. The spider web-like look is more consistent with what happens when repainting is done without carefully and properly preparing the surface. As I suggested in my post earlier in the thread, I suspect that there was transport damage or damage done on the lot and that the dealer just did a quick repair.
While I would guess with confidence that the panel was repainted (poorly), I also won't be surprised if the dealer gives you a hard time about doing a proper repair. My suggestion would be, before going to the dealer, to make a stop at a body shop and to have them check the paint with a paint depth gauge. If the paint is thicker than it should be, that would be a definite indication that the panel was re-painted, and, if you know that for sure, that would take away the dealer's likely excuse that the paint was cracking because of some environmental contaminant or because of something you did to the car.
If the dealer does not give you a satisfactory response, you should request the intervention from someone from Lexus corporate and to have that person examine the car and make a recommendation.
Also, what color is the vehicle?
Thanks for posting the picture.
Another thing that I would suggest is going to the Lexus Drivers website and entering your car's VIN number there. That will allow you to check the vehicle history. If there were any post-delivery repairs done to the car, they might be listed there, but that isn't always the case.
I've seen that exact effect happen when the various layers of filler and paint were not allowed to cure before the next layers were applied.
The reason why I asked about the color is because the Silver Lining Metallic is not the easiest color for which to get a good color match when repainting. Sometimes, if the area that needs to be repaired is very small, the shop can spot in new paint into the smaller area, blend it over a somewhat larger area, and, then, clear coat the entire panel. In other instances, to get an acceptable match with that color, it may require blending the new paint into adjacent panels.
As others have stated, Lexus is very customer centric; I believe they will help.
That's what I meant when I posted to call the dealer; I apologize if it sounded flippant.
And I agree, if they did it, somebody knows something.
Finally, a good painter can do wonders.
There is a guy near me who does all the work for the high end dealers around Silicon Valley.
Last time I was there he was fixing a chip on an Aston Martin.... Sheesh!
Good luck.
Good luck.
