How to change Home Address for "Go Home" Voice Command
My "Go Home" Voice Command directs me to the dealer's address and I can't seem to change it.
This is different to the Navigation Presets.
When I select "Go Home" Preset on Navigation screen it goes to my home address correctly, no problem.
Can somebody guide me how to the "Go Home" address for the Voice Command?
Mine is Lexus NX 2016
Cheers!
Cheers!
Menu>Setup>Navigation>Home>Delete
Then after you delete it, you can add the correct address.
Still same thing, when I do the voice command "go home" goes to my dealer's address.
Can anyone help??
when the car is running push and hold the volume **** in until it resets the nav unit. It should only be about 15-30 seconds until it restarts. If that doesn't work, disconnect the battery for 15 mins, do a full reset, if the physical go home button works but the voice command option sends you to the dealer, it sounds like the system isn't registering that you've changed the go home destination. The battery pull should fix that, only issue is you'll have to reset all your personal settings on the car, radio station, seat position, bluetooth, garage door, etc.
All other workarounds are just annoying and time consuming...get the professionals to fix it....
I've had a number of little annoying things such as aiming of headlights, turn signal timing, and non-led lights, and I just took it to my dealer where they fixed all the items for no charge while I munched on their donuts, drank their coffee, and test drove their cars, including a very nice RC F-Sport that had a sticker that would pay for at least two NXs...
Honestly, the best advice is to command your car to "Go Home," and follow your car's navigation system to your dealer and tell them to fix it!
Actually you're also right about the aiming of headlight, I found the factory setting was too low, too dangerous for driving on dark highway!
MJA1951
04-28-14 10:50 AM
DocRock143
06-15-08 09:44 AM
