Lexus Enform 2.0 to update with Apple CarPlay
#196
Can someone help me troubleshoot? Regarding a 2018 NX with Navigation (Panasonic):
I completed all the steps up until number 9 where you plug in the prepared flash drive.
After I plug it in, nothing happens. I don't get the "new software is ready to update" screen. Something like "Reading Flash Drive" at the top of the screen popped up momentarily right after I plugged it in, but that's it. Otherwise, it's like nothing happened. I can use the system like normal while the flash drive is plugged in.
I made sure the flash drive is formatted to FAT32. The actual flash drive has no other files other than the update, which is a folder entitled "L2-P2_D1031_M1030" that then contains all the actual files and folders.
Any ideas?
Any ideas?
#197
After I plug it in, nothing happens. I don't get the "new software is ready to update" screen. Something like "Reading Flash Drive" popped up momentarily right after I plugged it in at the top of the screen, but that's it. Otherwise, it's like nothing happened. I can use the system like normal while the flash drive is plugged in.
Any ideas?
Any ideas?
#198
Any ideas?
Any ideas?
#199
#200
#202
Can you post pictures of the update and or tell us how it is? There is some concern with what is actually in the update from that site since there's really no way of verifying what you are actually putting into the media center... IE: Is it legit toyota/lexus update or does it have other malware and such buried somewhere in it...
Thanks,
-Nigel
Thanks,
-Nigel
#203
Update completed in over one hour. Had to reinstall few times as lexus enform apps stopped working.
i thought there will be Amazon Alexa app installed. I dont see it. Was that included or not?
During installation there was new update for Enform (actually2) and then it was greyed out. I have unistalled and installed app on my iphone, reconnected and repaired bluetooth, but finally after deleting personal settings on a screen it connected.
#204
https://drivers.lexus.com/lexus-driv...e_Pager_v2.pdf
Is Lexus Enform App Suite still installed on the car?
#206
The EnForm App Suite came back without issue after an update. The Owners manual however can't be found. When clicking on owner's manual, it says "Unable to access the media. Please check that it is properly inserted." If anyone has any ideas on how to fix that, please let us know.
#207
you need to install the Lexus Alexa App...see link below for instructions:
#208
I was also able to update mine, 2018 NX300 FSport. Apple Carplay working perfectly.
Lexus Enform App was good.
Can't access the Owner's Manual though. Same error I got from above.
#210
Just saw the last part of the LSB. Here is the LSB on how to put the manual back and the link to the files. Both NX 300 and NX 300H
https://drive.google.com/open?id=1cE...RUuBpICCR4UY2p
The following 3 users liked this post by GabC:
