NX200t tuning list
#92
If that was possible, you would be pushing WAY more boost than you would want on that stock turbo (ignoring the possible effects on the engine). Our tiny turbo would just turn into a hot air blow dryer under high boost.
#93
TTi Motorsports stage 1 ECU + TCU reflash finally done on my NXt. Went out for a short drive after uploading files to the engine and transmission computers.
What. A. Difference. Mid-range is definitely livelier than it used to be. Transmission shifts fast and firm now, too. Just how it should have come off the assembly line. Can't wait for the next drive through them twisties.
#95
Piggyback tuners will give you a nice increase in low to mid range power, but the reflash tune is still stronger even in the top end as well.
#96
While peak power increased by less than 20 horses, most of the mid-range saw gains of around 30-40 horses. This was very evident in the way the car just wants to keep pulling and pulling, eliminating the need to downshift in most of this particular route's corners. Numbers quoted above are from other 8AR-FTS vehicles with the same tune.
TCU tune worked wonders in making shifts firm and snappy, particularly in S/S+ mode. Too bad my request to disable auto-upshift in manual mode wasn't fulfilled.
She just pulls and pulls in the video... No posted speed limits on this route. Nice to finally have the brakes and suspension sorted out, too.
#97
I'm at the other side of the ocean, and, lately, I discovered this kit of Chiptuning germany.
https://www.cpa-chiptuning.de/fr/chi...erbox_4443.htm
Looks very promising.
Dyno test show the maximal possible results. I'm not speaking "tuner language", but I believe that this means it is only reacheable with a changing of the headers and the intake.
#100
Thanks to your input. Though I don't know if BMS sold in our country.
If you allow me to ask a noobish question, but is it possible to have a piggyback that will not overrun the original car prog all the time ? What I'm trying to say is that I don't need the higher performances during rush hour on my local streets and highways. But only when I got to the montain road. So, for me, the ideal case would be that it switch on only when I put the car into sport+. Is it possible ?
#102
#103
BUMMER UPDATE: Electronic parking brake recall/reflash seems to have wiped out the TTI TCU tune. I'm not sure if the ECU tune was wiped out, but the car's definitely a lot more sluggish than it was when tuned. Wanted to download new BIN files from the ECU and send to Tony of TTI for him to implement the tune on the post-recall files, but Tactrix (tool) was dead out of the drawer for some strange reason. Currently waiting on a new Tactrix. It should get here in two weeks.
#104
The plus side on doing this is that the BMS boost setting is adjustable (with data cable) whereas the TOM's isn't.
I've seen where a re-flashed Lexus (reverted to stock) was taken to the dealer for service and they did an update to the ECU which changed the file identification (BIN) number. Because of this the tuned file was not able to be load since the file number changed and had to be redone by Tony. The Tactrix is powered by the USB cable. What error message did you get?
#105
