NX - 1st Gen (2015-2021)
nx200t 2016 blowoff valve or Bypass
Old 02-05-16, 03:22 PM
Luismh01
Luismh01's Avatar
Post nx200t 2016 blowoff valve or Bypass
I just change my Lexus 2015 IS250 for the new NX200t. Since it is turbo I want to hear that Pssshhhh louder. Which aftermarket Blowoff valve should I use to make it sound louder?
This is my first "Turbo" so I just want something plug and play that makes it sound good and doesn't damage the car.
Thanks
Old 02-05-16, 04:54 PM
coolsaber
coolsaber's Avatar
I would ask why, but to each his own.
Simple answer the engine is too new for mods. Your question would be better served with the guys in the IS or GS forum since this is they type of MOD, the aftermarket could care less about in a mini cute ute.
Old 02-07-16, 08:50 AM
legrunt
legrunt's Avatar
This car's bypass valve looks extremely integrated. Half its working portion is sitting inside the turbo housing itself, so replacing it is not an option.
I guess you could try to unplug it to disable it, then install another vacuum based non ecu controlled unit.
Or change your whole filter set up to an open pod unit so that the standard one sounds louder.
Or you could just push air through your teeth each time you take your foot off the gas.
Old 02-07-16, 12:58 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
A performance air filter such as Tom's (here) will allow more air resulting in hearing the turbo swoosh sound a little. As per coolsaber, check out the IS, RC, and GS forums for their 200t mods.
Old 02-08-16, 06:37 AM
Swacer
Swacer's Avatar
In all honesty, I think a BOV on this car would be a very odd, borderline ricerish thing to do.
A BOV on a SUV would make people be like...*raised eyebrow*
Old 02-08-16, 12:08 PM
NXOwner
NXOwner's Avatar
Location: Driving a UX Hybrid F-Sport! (in So California)
Wow...$129 ($160 MSRP) for an air filter. I would hope it is cleanable/reusable.
Old 02-08-16, 01:26 PM
15RC350F
15RC350F's Avatar
I'm pretty sure the "raised eyebrow" is the desired result. And maybe I'm a bit too PC, but the use of "rice" in this context is a bit sketchy.
Old 02-08-16, 02:28 PM
NXOwner
NXOwner's Avatar
Vote your "ricer" opinion here.
Old 02-10-16, 06:15 AM
15RC350F
15RC350F's Avatar
For the record, I don't care either way, as it's not a term I'm likely to use. I also happen to live in the land of "don't get offended unless offense was intended".
But do know that many consider the term to be a pejorative: https://en.wikipedia.org/wiki/Rice_burner
http://en.wikipedia.org/wiki/Rice_burner
Karimitsuu
03-12-19 08:08 AM
RcNick
Build Threads
06-14-18 05:33 PM
subaru
17
01-13-17 06:41 PM
Deladesign
01-09-16 08:15 AM
Woogie
06-04-04 02:02 AM
Quick Reply: nx200t 2016 blowoff valve or Bypass
