DIY oil change for 2015 NX200t - Page 2 - ClubLexus - Lexus Forum Discussion
NX Models (2015-present)
Old 02-23-16, 03:17 PM
Uglier
Thanks for the writeup but I have run into several problems doing this today.
1. There is no washer under the oil drain plug and no replacement washer of appropriate size with the oil filter kit, are you sure you had one? Nor is there a groove for an o-ring type washer to go in.
2. I am trying to remove the filter cap with the proper 65mm socket. The first one I got ($6) broke right off, cheap Chinese junk. I found an American one for $9, seems good, but I am pulling with all my might with a 1 ft long wrench and it does not budge. There is a metal tab that has to be pushed aside to let it rotate, but I have not moved it enough (any) to engage the tab. I'm afraid the plastic will break if I pull any harder. It is not reverse threads is it? Yes I know lefty loosey righty tighty,
Uglier is offline
Old 02-23-16, 03:24 PM
Uglier
Sorry on second look there was a washer, looked like part of the plug but came loose with a hammer tap. So only problem 2 stands.
Uglier is offline
Old 02-23-16, 03:30 PM
Uglier
Default Why prime a turbo?
I have owned Peugeot Turbos since 1987 and changed oil myself all the way along, never heard of this. When the engine is idling the turbo is barely spinning (if at all) so I don't see how it could be an issue. My first one lasted 250k and was running fine still when I scrapped it for the 2009 $4500 government clunker rebate, it was rusty anyway.
Originally Posted by rayzer57 View Post
Excellent detail and illustrations. Question: Does anyone remember the 80s when we had to prime the engine that were equipped with turbos. "Priming" was the process where after you changed the oil, you cranked the engine over until you registered oil pressure. When you change the engine oil and do not prime the engine, it takes about 15 seconds before the oil gets circulated, fills the oil filter, and reaches the turbo bearings. In essence, I hate the idea of the turbo spinning without oil pressure for 15 seconds or so with only the residual oil for the past oil. Priming was a standard practice for many manufacturers but it seems that some manufactures have done away with this simple practice.
I am just wondering if anyone who does their own oil changes primes their engine (after an oil change) before they start their engine. Or is their something in todays engines / turbos where that is no longer required. Lexus dealerships are not aware of this practice for a couple of reasons. One, most are very young mechanics and don't remember the good old days, and two, turbos are new to the Lexus mechanics (NX was the first new engine to Lexus that uses turbos) and according to the Lexus mechanic training, it is not required. I am just looking for a good technical reason why it is not required, or should it be?
Uglier is offline
Old 02-23-16, 04:06 PM
olgzr
This is the same filter and filter housing that was used on the 2009 Venza we had. I use the socket that I purchased from Toyota, the cheap one I had would slip. The filter housing is very hard to start, but I was always able to get it to turn. I never moved the metal tang, it just slips past the housing. We had that car for 120K miles and I changed the oil every 5K miles. It never got easier to turn. I've only changed the oil once on th NX, it was also very hard to turn.
olgzr is offline
Old 02-23-16, 04:23 PM
Uglier
Wow, if that's the way its always going to be it shows Toyota/Lexus engineering is pretty junky. (First Japanese car I've worked on in 30 years). No comparison to the German/Swedish/French cars I have owned. Based on this I'll go ahead and put the cheater bar on it tomorrow. Thanks so much for your response! We'll see if anyone else has anything different to say. Dave
Uglier is offline
Old 02-23-16, 04:30 PM
olgzr
Do verify you you are turning it the correct way, when you are on your back under the car, it's easy to accidentally turn it the wrong way.
olgzr is offline
Old 02-23-16, 04:58 PM
Uglier
I'm sure I'm going the right way. Not on my back, I have a lift.
Uglier is offline
Old 02-23-16, 10:37 PM
NXblue
Default DYI oil change
Thank you so much for posting this oil change steps w/ pics! Always nice to know, even if I won't be doing mine for some time, b/c my vehicle is so new & I don't drive that many miles, & the first 2 service trips to the Lexus dealer is free. I've been looking for pictures & info about the location and how the filter assy. comes off and hadn't found much help! I will be doing this eventually!
NXblue is offline
Old 02-24-16, 01:33 PM
Uglier
Default Additional Tips for Oil Change
OK here's some final tips to add to Savage's great writeup above
1. Get a solid oil cap remover like Savage shows, not a sheet metal one like they sell at AutoZone etc. They just slip or break. The right one cost $29 at NAPA.
2. Once I had the right cap remover the cap came off fine with a 4 foot cheater bar. Don't expect it to come off with just a socket wrench. Its weird how it went back to the same position after the filter change with very little effort.
3. Savage states his service guy said the oil capacity is 5.2 quarts, I put in 5 from a new Mobil 1 jug and drove the car to get it in the filter and then it was a full quart low so added another quart. Real capacity of mine is 6 quarts. Although note I do drain the oil very thoroughly, I get oil full hot on the highway then let it drip overnight.
4. If you have a lift and the lift is up do not walk straight into the steel ramp. I have a gouge and a bruise an inch under my eye. Finally put some high viz plastic over it. Ouch.
Uglier is offline
Old 02-24-16, 05:43 PM
brook41
Check your owners manual I believe it says 5.2 qts.
brook41 is offline
Old 02-24-16, 05:45 PM
Uglier
Yes it does say 5.2 quarts that's why I was pointing out its wrong (unless the dipstick is wrong)
Uglier is offline
The Following User Says Thank You to Uglier For This Useful Post:
TitanCi (12-19-17)
Old 02-24-16, 09:40 PM
acheuk
Straight from the owner's manual:
The engine oil capacity is a reference quantity to be used when changing the engine oil. Warm up the engine and turn off the engine, wait more than 5 minutes, and check the oil level on the dipstick
The oil level would be wrong if you turn off the engine and check the level right away.
acheuk is offline
Old 02-25-16, 04:38 AM
Uglier
I drove it to Walmart and back, about 15 minutes total, then waited another 15 minutes.
Uglier is offline
Old 12-18-16, 04:11 AM
Joelinnh
Joelinnh's Avatar
Smile
Nice write up thank you
Joelinnh is offline
Old 08-01-17, 02:21 PM
dvdmull
Nice Pic's..... Many thanks..... Was waiting for a NX-F Sport oil change. I just got mine replaced which was a one time only here in Las Vegas. Looking forward to replacing my own soon. Just don't like the entry level personal who do just oil changes and tire rotations. All four of my rims have nicks in them because of someone must be blind removing or re-installing the lug nuts. I cringe at the thought of a dry re-start after oil change and revving up the engine. I used to crank my Camaro until the oil light turned off before putting the fire to it. So from now on I'll be doing it myself. Thanks again......
dvdmull is offline
Quick Reply: DIY oil change for 2015 NX200t
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
