NX - 1st Gen (2015-2021)
⚡ Fuse Box Diagram? 📜
Old 10-05-15, 09:06 PM
NXOwner
NXOwner's Avatar
Location: Driving a UX Hybrid F-Sport! (in So California)
Question ⚡ Fuse Box Diagram? 📜
Are there fuse box diagrams available for the three fuse boxes in the NX? The manual just shows the location of the three fuse boxes, but not a "legend" or map of each fuse, their amperage, or what they protect .
Old 10-07-15, 08:55 PM
computerwi
computerwi's Avatar
A cryptic abbreviation of fuses is labelled right on the fuse box cover for the one in the driver's footwell.
Old 10-07-15, 10:21 PM
NXOwner
NXOwner's Avatar
Cool. I'll check it out this weekend if I get a chance. Thanks!
Old 10-22-15, 10:13 PM
NXOwner
NXOwner's Avatar
Default ⚡ Here is the fuse diagram and layout ⚡ ...
For those DIY'ers, here are photos of the interior fuse box location, map, and actual fuses on my U.S. 2016 Lexus NX200t.
The fuses are "Low-Profile Mini" blade-style, so keep this in mind when purchasing an "Add-a-Circuit" for your project.
Fuse Map:
Actual Fuses:
Old 05-01-16, 12:51 PM
2016nx
2016nx's Avatar
Default help> WHERE?
I answered my own question. It took a mirror to see it....
Old 05-27-16, 12:40 PM
Earman
Earman's Avatar
Thanks for posting the list, much easier to read it that way than on the car!
LexiGyrl23 (07-01-20)
Old 06-19-18, 04:52 PM
LINSTEFAN
LINSTEFAN's Avatar
Trying to hardwire a dashcam, does anyone know which one is for the cig lighter because it seems like none of them are labeled "CIG"
Old 06-19-18, 10:59 PM
NXOwner
NXOwner's Avatar
It's probably the one labeled, "ACC" for accessory port.
Old 06-20-18, 11:33 PM
LINSTEFAN
LINSTEFAN's Avatar
Have you tried tapping to the "acc" fuse and experience any issues? I've been searching for a fuse diagram that explains what each fuse is because the one on the cover doesn't really have good abbreviations and still had no luck. The only results i've found is people is tapping a add a circuit to the "CIG" fuse but apparently for newer cars we don't have that. Correct me if i'm wrong but did they replace "cig" with "acc" in the newer cars? Like what's IGU,ECU,P/Outlet,TI/TE,etc. I mean the ones that are obvious are like Wiper,Washer,tail,bkup lp.
Old 06-01-19, 07:28 AM
colshie58
colshie58's Avatar
Default CIG Fuses
The cigarette lighter or 12v power socket fuses are labelled as P/OUTLET No1 (front outlet in the centre console) & P/OUTLET No2 (which is in the Boot/Trunk)
The following 2 users liked this post by colshie58:
5h40573r (07-02-19), Nx350fspt (04-29-22)
Old 07-02-19, 09:38 AM
5h40573r
5h40573r's Avatar
Thanks for the info i was planning to add usb ports to the left of the driver seat to make charging phones on mounts easier. this makes the project much easier.
Old 12-23-20, 04:01 AM
VladT
VladT's Avatar
trying to install my dashcam and I am not clear at all what fuse in my NX would have always on power; which fuse is the one for hazard lights?
any other fuses that could serve the same function?
please help
Old 12-23-20, 08:03 AM
jonnyyaa
jonnyyaa's Avatar
please help
hi,
I did this on my viofo a119 v3 dashcam - yellow wire to power outlet 2. . I used the power seats for my red wire. Black wire needs to be grounded. Merry Christmas!
The following 2 users liked this post by jonnyyaa:
Nx350fspt (04-29-22), VladT (12-23-20)
Old 04-02-21, 10:20 AM
WIZARD1325
WIZARD1325's Avatar
which fuse is it for the interior trunk lights?
Old 04-03-21, 06:37 PM
n0v8or
n0v8or's Avatar
Luggage area lights are marked with green circles. Fuse for this circuit is marked with a red circle.
This fuse is located in the fuse/relay box mounted on the left fender apron.
Quick Reply: ⚡ Fuse Box Diagram? 📜
