Extremely flimsy sheet metal?
Hey guys, I just noticed today washing my car that the panels on this car are very flexible and easily pushed in in many place on the body. The worst being the hood and the front doors. They will actually bend and push in even while applying the amount of pressure you would use for drying the car with a microfibre. Of course, it always snaps back into shape but I just found it a little odd. Anyone else felt the same?
I haven't tried pushing in the panels but my previous car, 2012 camry, had the same flex in the panels.
Compare that to the previous generation, 2007 camry, that car had thick metal panels.
it's all to save weight.
Just the further extent of global economy an "built by the cheapest bidder".
Hoods and other pieces of the car have begun to get thinner and thinner for various reasons. Those include:
1. Cost - thinner metal is cheaper
2. Weight - thinnr metal is lighter
3. Crash Safety Ratings - During a crash, the hood will collapse and be destroyed, the frame is the only real concern. So why put any strength or money into something that will just bend and be destroyed quickly?
With that said. The hood on my genesis coupe was this way, so is the NX and IS. My Camaro is thicker metal, but lets also keep in mind that the "coupe" is 4000lbs.
As for the paint, that's another story, Japanese paint has historically been weak, so gotta clear bra that stuff early.
The pursuit of F
Never felt the sheet metal was unusually thin and I've washed it several times and sealed it once. I agree the hood is thin (but due to its aluminum), but the worst offender to me is the never-experienced-in-any-car cheap creaking plastic exterior mirrors.
My first concern was the rear of the roof panel around the antenna "fin". It easly pushes in with just a finger press. I noticed it just prior to having my roof wrapped and had to advise the shop to be very careful in that area when applying the vinyl. The roof on my IS would give a bit under pressure when waxing but not nearly as severe as the NX does.
My roof is completely flat. And so is every other NX in Malaysia.
Looking at online pictures, yeah, I can see that NXs in some other countries are equipped with the fin type antenna. I wonder why the inconsistency....
The pursuit of F
Do you have Satellite radio?
Glad I'm not the only one haha. Even my 07 IS250 felt more solid. I guess time will tell if this sheet metal is truly up to the task. This car's too beautiful to be damaged
The hood is especially thin to ensure it isn't fatal for any pedestrians - thats the main reason for it although it does lead to secondary advantages eg weight, cost
I think its the other way around to be honest. Cost > Safety. Played out to make it seem like its safety first. If that was really the case, it would be just on the hood but its everywhere on the car.
Out of curiosity, I went to the dealership and checked the NX out again. I only tried to push the hood, front doors and the roof around the antenna. Not a good idea to push the car extensively in a showroom...
Honestly, I find the front doors are not as flimsy as reported. Yes, it is a tad flexible than say, the front doors of 3IS. Ditto for the hood. But it is not a concern. I guess the metal for the door is made to be thinner than usual in order to create creases for the unique shape of the doors.
The only area on the roof around the antenna fin is the only area which I find it too flexible to my liking. As experienced by another fellow member, mwl7698, you can literally use a finger to make the area flex. I would concern how it stands to hail damage...
With regards to the amount of pressure when drying the car with a micro fibre, no offence but you really have applied too much pressure. It would mar the car if you have missed a spot when washing or if the micro fibre cloth is not of the greatest quality. Put some quality was/sealant/coating and you shouldn't need to dry a car with that amount of pressure.
