NX - 2nd Gen (2022-current)
Digital mirror
Old Sep 16, 2023 | 08:09 AM
GoldenYear's Avatar
GoldenYear
So as Auto Pilot
Old Sep 16, 2023 | 08:15 AM
GoldenYear's Avatar
GoldenYear
I see Amazon is selling lots of RV mirror with recording cameras but it's a sloppy installation with bunch of wires all over the place.
Old Sep 21, 2023 | 05:25 AM
Skedadle's Avatar
Skedadle
Originally Posted by Randyp1234
At the risk of hijacking the thread, is it safe to assume that being able to see "out the back window" if you have a bunch of cargo blocking the window is the only point of the digital mirror? What's the point otherwise?
I thought the same thing until I had it. After 6 months I'm not sure how I would go back to the narrow regular mirror.
Told the dealer I would never use the digital mirror. My spouse told the dealer we would never use it. Turns out we were both wrong and now never turn it off. The digital mirror gives you a wide view of the back without the posts, headrests, or anything else. You can see several lanes behind you while driving, in parking lots, and at stops. The mirror ignores the problems related to tinted windows when it starts to get dark.
Use it for 60 days and then try to go back to the regular mirror. The only negative is that you have to remember to use the visor mirror if you want to see if you have any food in your teeth.
Old Sep 21, 2023 | 05:57 AM
Billst's Avatar
Billst
I wear progressive lenses and thought at first the mirror was bad.
After 100miles I was absolutely convinced they were much better.
But then I changed my glasses.
Standard progressives do not have such a wide field of vision. So twisting your head is needed.
I began to wonder what I saw in the digital mirror.
When I went back to Zeiss drivesafe lenses then I again had the full advantage of digital mirror.
Instead of moving my head,
I just flick my eyes to the mirror to have a perfectly clear view.
The combination is amazingly good.
So if you wear lenses, try Zeiss, you may find the full advantage.
The link below is U.K. so you may need to select a country specific version.
https://www.zeiss.co.uk/vision-care/...r-driving.html
USA:
https://www.zeiss.com/vision-care/us...ve-lenses.html
Old Oct 20, 2023 | 09:21 AM
SnF2023's Avatar
SnF2023
8th Gear
Your rear view camera should not get hot. That's not normal, get it checked out.
Old Oct 26, 2023 | 08:06 AM
Lexicon1's Avatar
Lexicon1
Does the rear view digital mirror distract you when you are driving at night? I would "assume" it would be somewhat bright and perhaps be a distraction???
Old Oct 26, 2023 | 08:09 AM
LiBeRtAs's Avatar
LiBeRtAs
I don’t think it distracts me but the brightness of the headlights does make it difficult sometimes to see what is in the mirror because the camera is so different from a mirror.
Old Oct 26, 2023 | 08:52 AM
Droid13's Avatar
Droid13
Two issues at night.
a) like many cameras, at night when viewing bright lights (aka other car headlights) the camera produces a glare around the light, and dark areas can be a bit grainier which does not affect the typical mirror. I would say its less bright than an ordinary mirror in day view position as there is some automatic adjustment in light level. It is a tad brighter than an ordinary mirror in the night view position. Its not really a distraction though, just my own observations and doesn't really limit its function.
b) The refresh rate on the mirror's screen isn't super fast. That means that when a car passes you in the opposite direction, their tail lights instead of just being red lights moving thru the field of view, show as a streak of red light so can for an instant out of the corner of my eyes appear like flashing red lights. That can be a bit distracting until you get used to it, after all, who likes to see flashing red lights in their rear view mirror.
Old Oct 26, 2023 | 08:54 AM
LiBeRtAs's Avatar
LiBeRtAs
Very well written, you should write for a living.
Old Oct 26, 2023 | 10:25 AM
Billst's Avatar
Billst
We normally have a second optical mirror alongside the driver’s mirror for the passenger to also view the back. Not needed with the digital mirror : it can be viewed from all other seats.
Old Oct 26, 2023 | 10:36 AM
SnF2023's Avatar
SnF2023
8th Gear
It is harder to see cars in the digital rearview mirror at night. I can see their headlights, but not a full view of the vehicle. That being said, I don't get blinded by the car lights at night either. Another thing I really like about my digital mirror is that I can lift the flap on the cargo cover and stop lights & sunlight from shining through the rear window and on my grandbabies (rear-facing car seats) without obstructing my view. No more sun in their little eyes.
Old Nov 27, 2023 | 03:20 PM
calvin12's Avatar
calvin12
To address the glare issue at night, has anyone attempted to add an anti-glare film either on the digital rearview camera lens or on the section of the window directly in the camera's line of sight?
Old Nov 27, 2023 | 03:22 PM
LiBeRtAs's Avatar
LiBeRtAs
No I have not but I’d be curious to see if someone would do that if it helps because the glare is really quite something!
Old Nov 28, 2023 | 04:06 PM
Mylexus2's Avatar
Mylexus2
7th Gear
There is an option "On" and "Off" for antiglare on both the digital mirror and the regular mirror. I have no idea if an anti-glare film will help on the camera view.
Old Nov 29, 2023 | 08:41 AM
jgrnt1's Avatar
jgrnt1
I've had my 2022 NX 350h for almost a year and a half. I had not really used the digital mirror much at all. I viewed it as a novelty. For Thanksgiving, we took a family trip with 4 adults, 15 hours of driving each way. The back was packed almost to the roof, so we had to use the digital mirror. I was pretty impressed with it. I'm not sure if I'll use it all the time now, but it seems to work very well.
