ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   NX - 2nd Gen (2022-current) (https://www.clublexus.com/forums/nx-2nd-gen-2022-current-313/)
-   -   USB voice commands don't work (https://www.clublexus.com/forums/nx-2nd-gen-2022-current/983271-usb-voice-commands-dont-work.html)
PhilW1952 Mar 23, 2022 03:56 PM
I like to play music from a USB stick, rather than stream or from a phone. On a 2021 NX, saying "Play song", it plays from the stick perfectly. On our new 2022 NX, we get the message "Can't perform this action on USB".
Also, there is no way to search the USB, just a clunky manual scroll. If I try to search, I'm told to log onto Apple to stream, which I don't want to do. Also Apple is the only choice for default streaming. This all seems to be step backwards!
Anyone else seen this?
ct6978 Mar 23, 2022 10:04 PM
Hi PhilW1952,
Do you mean search via voice command? The USB browse function via the touchscreen seems to have all the basics, folder, artist, genre, etc....although they're a little slow to load initially. I didn't try the voice command, though.
In case you use playlists, I started using isyncer to populate the USB drive when Toyota./Lexus dropped their playlist support some years ago. It both renames the track (I have it add a sequence number prefix) and writes them sequentially based on iTunes playlists, with separate folders per playlist. Works well if you want to invest the time and it fits your needs, but might not be what you're looking for based on your post.
ct6978 Mar 24, 2022 08:53 AM
PhilW1952,
I just posted the details on the new OTA patch, one line caught my eye in regards to your questions, not sure it fixes your issue(s) but maybe....?
"Abnormal USB audio playback when using voice recognition"
PhilW1952 Mar 24, 2022 12:29 PM
Originally Posted by ct6978 (Post 11253959)
Hi PhilW1952,
Thanks for the comments - yes it is the lack of voice commands that used to work that is a little annoying!
PhilW1952 Mar 24, 2022 12:34 PM
Thanks, it doesn't look like they have fixed from the list in one of the replies to your post, but I will try it.
