Sunroof noise
My Japanese-built NX 350 Takumi was delivered in 2022 and I complained about a driver’s door rattle. The mechanic also thought it was in the door.
On investigation, it was found not to be in the door but was a loose bracket on the Panoramic roof. They packed the bracket with felt and torqued the bolt up. That solved it.
You may have a similar issue from the build so I would recommend getting it fully sorted by the Dealer whilst the car is still fairly new. There isn’t always a direct relationship to where the noise appears to come from and the actual source of the noise!
