NX - 2nd Gen (2022-current)
dash cam
Old Apr 30, 2023 | 04:21 PM
2ball's Avatar
2ball
Default dash cam
Has anyone added a dashcam to their Lexus? pics? I assume there is power from the rearview mirror I can split?
Old May 1, 2023 | 06:16 PM
lsft's Avatar
lsft
Old May 1, 2023 | 06:48 PM
Teasy010's Avatar
Teasy010
I installed the fitcamx front and rear one because I like the oem look. I hardwired it so it can record even when the car is off for parking mode.
Old May 2, 2023 | 06:44 AM
lsft's Avatar
lsft
When you hard wired it to the fusebox, does it beep or give you any signal that it recorded something while parked?
Old May 2, 2023 | 10:22 AM
Xanadu350's Avatar
Xanadu350
That would be cool if the Lexus OEM dashcam could record while parked if someone gets too close to your vehicle.
Old May 2, 2023 | 12:25 PM
Aloha808's Avatar
Aloha808
I installed the integrated dashcam last night in my NX350h. I was drunk and was very careful and it took me 4.5 hours start to finish including some messing. I was very slow and could do it again in under 1 hour if I was less careful. If you do it yourself and follow the directions be careful unplugging the large white wire harness that goes to the lights console, there was a single tiny clip that broke off. You need to buy the wire harness that is a y shape. Its really hard to fit everything up there in the correct place without the headliner bulging as the wires are too long so that was the most difficult think. Get the bulletin they send you when you buy the parts from Bell Lexus which has them for 350 including the separate needed Y harness. Also when you use the bulletin, you'll see the printout template is actually a little off because the 10cm is actually 9.5cm. This means if you're not careful it will not match up correctly. Line up the windshield dots on the line and then get the angle correct, ignore the blackout line at the top as it should be .75cm below the blackout line. If you line it up for the black dots instead of the top blackout line it will be in the correct place. Check Bell Lexus's ebay listing if you need the part numbers and wanted to buy locally. It worked fine when I installed it but after reinstalling the battery my settings were off so I had to reset them (mirror folding in when locked, trunk height setting and trunk open close setting required several on off cycles before I was able to open and close the trunk again. Also BEFORE you uninstall the battery open the drivers door and don't close it! It's a pain to open with the battery unplugged.
BTW, the fitx cam which is non OEM actually looks nicer than the Lexus Intergrated on and is probably better option. I actually got 2 of the Intergrated dash cams for free, one was accidentally mailed to me and the other was a free part I requested from the dealer when I bought the car. I would have got the fit cam if I was having to buy it. Much less intrusive and actually looks built in unlike the lexus one which is way over priced. Video quality isn't that great in the lexus one either. I'm actually concerned it might not be able to get license plate numbers in some cases which is kind of lame. Can't complain because it was free but would never pay 500 for the part + 500 for the install at a dealer for it.
Old May 15, 2023 | 07:37 PM
d2k2vic's Avatar
d2k2vic
If you don't care about parking monitor, you can get power from the rear view mirror with a plug n play adapter with USB A port. See this link:
Amazon Amazon
I installed the Viofo A139 Pro on my wife's NX 350 and used that plug adapter to draw power from the rear view mirror connection. The plug is a little pricey but saved me a lot of trouble and was much faster than doing a hard wire to a fuse box/tap. It also comes with a USB A to USB C cable, and a USB A to Micro USB cable.
Old May 16, 2023 | 07:54 AM
Nayon's Avatar
Nayon
For those that hard wired via fuse box, which fuse did you tap into? About to do mine, I have the VIFVO rather than FitCam.
Old May 17, 2023 | 06:12 PM
zanewyn's Avatar
zanewyn
You can reference LstoneX's picture in this thread. I hardwired my Viofo A229 using those fuse slots
https://www.clublexus.com/forums/nx-...use-panel.html
Old May 26, 2023 | 12:08 PM
mookieson's Avatar
mookieson
Does the Lexus genuine Dash Cam live stream on 14 inch screen?
Old May 26, 2023 | 12:23 PM
bottled's Avatar
bottled
5th Gear
Hard to tell by the video, but would this work with the NX with digital mirror?
Amazon Amazon
Old May 27, 2023 | 09:37 AM
d2k2vic's Avatar
d2k2vic
https://www.amazon.com/Dongar-Dashca.../dp/B07BH4G1NW
Yes, my wife's NX350 has the digital mirror and I used the adapter to draw power from from the 10-pin plug in the housing.
Old May 29, 2023 | 06:57 AM
Droid13's Avatar
Droid13
Nope, its just an ordinary dash cam with an extraordinary price tag. You can live stream on the 14" display from the built in front camera, but only at low speeds.
Bronsin
IS C
Feb 17, 2025 10:28 AM
DeeDeeRX
GX - 2nd Gen (2010-2023)
Mar 2, 2023 12:04 PM
SuperGT
Jul 8, 2019 04:20 AM
stamphead
NX - 1st Gen (2015-2021)
Aug 14, 2017 06:44 PM
edittman1
Feb 19, 2015 07:21 PM
