ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   NX - 1st Gen (2015-2021) (https://www.clublexus.com/forums/nx-1st-gen-2015-2021-264/)
-   -   Power liftgate doesn't work unless I first manually open it (https://www.clublexus.com/forums/nx-1st-gen-2015-2021/975794-power-liftgate-doesnt-work-unless-i-first-manually-open-it.html)
Alexdumitr Nov 4, 2021 03:27 AM
Every day when I try to use the liftgate it opens just a bit and starts beeping. If I manually open it completely it then works for the rest of day and the next day it does the same thing.
Do you have any idea what could it be? A sensor maybe?
angelslex May 28, 2023 02:24 PM
did you fixed this? Im having the same issue on NX200T F Sport
Alexdumitr May 28, 2023 02:32 PM
No, I didn't fix it, but I think I'm getting close on finding the issue. What I know for sure is that it only happens after it rains, so I suppose some humidity reaches a sensor.
I plan on changing that sensor, but I just didn't have the time and patience for it.
angelslex May 29, 2023 05:08 AM
Alex do you know where the sensor is? Thanks
